Results 121 to 130 of 130
Thread: Mercury in line 6 hop ups
11-28-2017, 05:01 PM #121
It is the deflector piston design that is the major limiter. The "Direct Charge" was a 10hp+ improvement over conventional deflector.
11-28-2017, 05:25 PM #122Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
says who......
12-03-2017, 04:59 PM #123
supercharge a la the verado......
12-03-2017, 05:03 PM #124
f you look the 1250 BP was a deflector motor rated at 125 crank horsepower and 99 cubic inches. The 1250 Super BP was the same displacement but a direct charge piston design and rated at about 140 HP ( ish ) . no other real modifications were made to the SBP motor, so one can assume the direct charge design DID offer a significant HP improvement( 10-15%) . Exhaust chest was the same size, carbs were ALMOST identical......not much else different......and the 1250 SBP turned into the production 135 HP motor... still about a 10% increase from the 1250 BP.
04-11-2018, 10:22 AM #1255000 RPM
- Feb 2005
- North Shores of Boston
- 515
I have enjoyed building a number of inlines. An old school racer told me the transfer cover with the ramp into the transfer wasn't needed he said all the fast guys would just machine up a flat aluminum plate and bolt that on. Is that True?? Mark 75H over the years I have read a lot of misinformation you wonder some times what works and what doesn't. I have been building 2 stroke motorcycles engines for over 45 years. I always go conservative and work up slowly, because it is real disappointing when you over build an engine and it falls on it's face unless completely wide open throttle WFO lol
04-11-2018, 07:08 PM #126
Its complete BS. I have never seen this on any Merc made after 1952. If it worked, all the factory team motors would have had it.
You may add whoever told you that to the list of people to ignore. Its sad that there are so many people out there willing to make stuff up like this. You never know which end of them the stuff is coming from.
04-12-2018, 09:58 AM #1275000 RPM
- Feb 2005
- 515
Thanks for the reply. Actually the fellow that said that to me was an old boat collector I used to work with. So no worries we will not have to ignore him he doesn't come to this site.
I switched to 200hp 2.5 v6's 10 years ago and never looked back. I do have a couple of inlines left I need to build and sell one of which is a 1500xs bored .015 with Vertex high domes. I left all the ports as is and only lightly cleaned up the casting flaws.
Thanx again,
Jamie
04-12-2018, 10:21 AM #128Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Jamie
Check the threads last couple days, someone is looking to buy a 1500 inline. How does it run?
04-12-2018, 11:35 AM #1295000 RPM
- Feb 2005
- 515
actually I stated I have a couple of inlines left I need to build.
After I get my boat finished, I hope to get to building the inlines and sell them. I will hang on to the XS that my find a happy home on a 1971 Sidewinder.
04-12-2018, 11:43 AM #130Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Ah, I thought two to build, plus one ready.
Mercury 2.5 fuel line
By STELLIX in forum Technical DiscussionReplies: 2Last Post: 04-21-2017, 05:57 PM -
Mercury in line C blocks
By Tom Smyth in forum Technical DiscussionReplies: 17Last Post: 09-22-2015, 07:38 PM -
mercury in-line 6 150
By panhauling in forum Technical DiscussionReplies: 2Last Post: 08-19-2010, 07:58 PM -
mercury 115 in-line 6 firing help
By Javelin409B in forum Technical DiscussionReplies: 8Last Post: 05-22-2008, 01:59 PM
