Results 1 to 8 of 8
06-18-2017, 08:17 PM #15000 RPM
- Jan 2017
- Albany NY
- 397
- 28
- 20
- 98
- 125
checkmate pulsare 2000 jackplate question
I have a 06 Pulsare 2000 with a 225 Optimax, 13.5" of setback spinning a 25tempest prop.
I have been fiddling around with the jack plate height, and I'm just wondering where everyone else runs there's.
I had it at 4" below the pad and then moved it to 2 7/8" below the pad. I got around 70-72mph. I would think I should be in the mid 70s with this boat.
06-18-2017, 10:13 PM #25000 RPM
- Mar 2010
- Alberta
- 363
- 15
- 33
- 29
- 231
For maximum speed, Checkmate 20-2100 Pulsares like the prop centerline even with pad or 1" above the pad with that much setback.
08 Checkmate 2100br 250xs
JUPITER PULSARE liked this post
06-18-2017, 11:30 PM #3
Probably can't run that high unless he has low water pickups. Run it about 2.5" below if you have a stock case and try a 26 Trophy prop. Running the case high only seems to work once you get over 80 mph, which you won't do with a 225. Also, setback of up to 16" will help speed also.
Boat Delivery available
Things owned. NOTHING!!
06-19-2017, 09:22 AM #4
Randy is right about the prop. A Trophy Plus 26, maybe even a 27 will improve top end speed and handling of the boat. You will need low water pickups to go higher on your motor height. If your nosecone has water pickups, you can tap and plug the top three holes on the "gills" of your case to prevent sucking air. You should be seeing speeds in the 75-77 speed range once setup correctly. Your 13.5" of setback is right on the money without sacrificing lower speed handling.
J-Town Hot Boat Team
Barracuda 188CCR/Suzuki 140
Past Boats:
Checkmate 2800SX/Twin Merc 250’s
Checkmate Pulsare 2400/Verado 300
Checkmate Starflite/Merc Pro XB250
Canadian Edition Hydrostream AE-21/Merc 2.5
Checkmate Pulsare 2100/Merc 225Xri
Hydrostream Valero YT Bowrider/Merc 175
Talon T-21/Mercury Racing 2.5 Carb
Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
Velocity 230/Mercury 454 Magnum
Scout 172 Sportfish/Yamaha 130
SeaRay F16 Jet boat/Mercury SportJet
SeaRay 17' Seville/Merc I/O
06-19-2017, 11:19 AM #55000 RPM
- Jan 2017
- Albany NY
- 397
- 28
- 20
- 98
- 125
thanks guys, can someone explain the low water pickup better to me. I current have the four holes on the back of the gear case. I know on a bravo drive this is considered a low water pickup. I'm assuming its different on an outboard.
06-19-2017, 11:57 AM #6Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
06-19-2017, 11:59 AM #7Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
06-20-2017, 10:49 AM #85000 RPM
- Jan 2017
- Albany NY
- 397
- 28
- 20
- 98
- 125
Interesting, So what your saying is; in this picture the four holes on the back end of the nosecone is NOT considered a low water pickup
Checkmate pulsare 2000 brx 250 pro xs
By boatcrazy69 in forum Hulls larger than 20'Replies: 13Last Post: 03-03-2019, 03:08 PM -
Checkmate enchanter jackplate question?
By tunnelflite in forum General Boating DiscussionReplies: 1Last Post: 05-28-2015, 08:47 AM -
1994 checkmate pulsare prop question
By checkmatepulsare813 in forum Props, Setup, and RiggingReplies: 6Last Post: 04-10-2014, 09:52 PM -
Good Prop for my Checkmate Pulsare 2000
By Slickfriction in forum Technical DiscussionReplies: 0Last Post: 07-30-2009, 12:56 PM -
Checkmate Pulsare 2000 BR VS Pulsare 2100
By promax150 in forum General Boating DiscussionReplies: 1Last Post: 07-19-2007, 09:09 AM
