Results 1 to 5 of 5
Thread: Tach works intermittently
06-18-2017, 12:03 AM #1Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
2000 90hp Mercaha FourStroke... Stock recreational/fishmotor
Motor runs great. But for some reason, the tach only operates at or near idle, and even at that, sometimes not at all.
I'm inclined to think I need a new tach, since whatever is driving the tach is not causing to motor to run poorly... But that would be a total guess.
I want to have a working tach again especially since this pig is propped for holeshot, not speed and since it's a four stroke it likes a little more rpm... But I don't want to overrev it either. So I want a working tach.
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
06-18-2017, 09:54 AM #25000 RPM
- Sep 2011
- Deplorableville
- 740
- 1281
- 76
- 3144
- 1452
There should be a small dial for pole settings on the back of the tach. Look what number it is set on now, turn the dial up and down several times and return it back to the original setting and try it out. I have had them start doing that too and sometimes that will fix the problem. Also check the wiring connections on the tach and the grounds on the motor.
06-18-2017, 02:48 PM #3Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
Thanks mate. I'll swing pole switch around here and there and see if that helps before I sink money into a new tach.
__________
the wet:
the dry:
2003 bmw ///M5
06-23-2017, 02:46 PM #4Team Member
- May 2009
- 1,875
- 557
- 76
- 636
- 301
- 6 Post(s)
Here's a related question...
The tach pole switch is set at 6p. That's probably where it's always been since I got it back in 2011. For whatever reason, I just assumed that's the right setting. I just took a quick scan through the factory service manual though, and it doesn't say (unless I missed it), what setting to set your tach to.
What's the right way to find out?
2000 Merc 90hp FourStroke
__________
the wet:
the dry:
2003 bmw ///M5
06-24-2017, 08:23 AM #56000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
To verify tach accuracy
1. Get out your timing light
2. Aquire a stop watch
3. Hook timing light to #1 cyl
4. Either hook flushing adaptor to motor or put boat in the water.
5. Start and idle motor
6. start stopwatch
7. count timing light flashes REALLY fast for one minute
*Note* in absence of a timing light you can just hold onto #1 plug wire with a wet hand. Although this method has shown to make it harder to keep track of your count.
But to answer you question, yes 6P is the correct setting. Lol
pcrussell50 thanked for this post
Need help with why tach works with two of my 3 motors, but NOT wtih 1991 Merc 200 hp
By Valero2.5 in forum Technical DiscussionReplies: 3Last Post: 05-27-2015, 10:44 PM -
tach works part time and no top end horse power
By vh/procraft in forum Technical DiscussionReplies: 4Last Post: 10-03-2014, 08:28 AM -
RPM window switch that works with OMC tach output?
By STV_Keith in forum Technical DiscussionReplies: 0Last Post: 03-17-2009, 05:57 PM -
Tach works in Neutrel, but no in gear.
By PHISH in forum Technical DiscussionReplies: 3Last Post: 08-09-2006, 05:56 PM
