Results 1 to 15 of 24
Thread: Broken Sporty!!!
06-15-2017, 10:23 PM #1
Broken Sporty!!!
WillySteve Hendricks
20XDC Bullet/Modified Merc 260
295TF Charger/ProMax 225x-Sold!
'83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
'85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
Freedom 240 DLX Fisher Toon/Merc 115
10' Cougar Cub/Merc 25HP On The Bottle!
18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
06-15-2017, 10:34 PM #2
Oh....and I presume all the shafts are the same, regardless of gear ratio???
06-16-2017, 07:38 AM #3
Dave Strong, WillySteve liked this post
06-16-2017, 08:58 AM #4
06-16-2017, 09:02 AM #5
06-16-2017, 09:08 AM #6
I'm fixing a torque master right now that broke in same spot for no apparent reason. Also took gears out. I was thinking about going to fat shaft after I broke my small shaft. But looks like they both have problems with breaking with age.
06-16-2017, 09:15 AM #7
Mine had bad case threads from factory, when the nut slipped tension from shift dog made her snap right in the middle of slot. Stock shaft was small but no more smallshaft so went fatshaft. Had to get case threads fixed.
06-16-2017, 03:41 PM #8
So, anybody got one laying around?
Cost is mucho at Pro Marine.......it's hard to believe the markup is only 28 bucksWillySteve Hendricks
06-17-2017, 11:34 AM #95000 RPM
- Sep 2011
- Deplorableville
- 740
- 1347
- 76
- 3211
- 1452
Did it break at high speed or taking off? Just curious how the boat reacted when it broke. That's one of my biggest fears, losing a lower at 80+.
06-17-2017, 12:01 PM #10WillySteve Hendricks
06-17-2017, 12:09 PM #115000 RPM
- Sep 2011
- Deplorableville
- 740
- 1347
- 76
- 3211
- 1452
At least you are ok man. Sorry about the prop shaft, especially right before vacation.
WillySteve thanked for this post
06-17-2017, 01:01 PM #12
We haven't made the reservations yet.....Thank Goodness, so I'll have some time to git'r fixed!
06-17-2017, 07:26 PM #13
hope you marked where it happened.
then go down and retrieve the prop and what is left of the shaft.
provided its not in 100 feet plus of water.
06-17-2017, 09:58 PM #14WillySteve Hendricks
06-17-2017, 10:28 PM #151980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
2.5 Sporty
By Varmint in forum Lower UnitsReplies: 6Last Post: 02-12-2016, 07:17 PM -
sporty
By michael lang in forum Parts WantedReplies: 0Last Post: 06-18-2015, 10:44 AM -
wtb bad sporty
By xskeetshooter in forum Lower UnitsReplies: 1Last Post: 07-25-2014, 10:30 AM -
Mercury Tech: sporty
By justinn in forum Technical DiscussionReplies: 0Last Post: 05-09-2009, 10:57 AM
