Results 61 to 75 of 182
06-19-2017, 03:07 PM #61Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
06-19-2017, 03:15 PM #62
Per the reed stuffers: If memory serves me V6's are not interchangeable with the V4. Though they look almost identical. So make sure yer gettin V4 stuff ...
06-19-2017, 03:18 PM #63'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
06-19-2017, 03:39 PM #64
[QUOTE=71V153;2963805]Go for it. Good reeds. Been runnin em for a few years now. Plus when ya run Carson's you can open/square up the reed cages.
Sorry 71V153 i dont know what you mean by open/square up the cages ?
06-19-2017, 03:42 PM #65Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
06-19-2017, 04:42 PM #66'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
06-19-2017, 04:46 PM #67
Thanks bud i got you now.
06-19-2017, 04:50 PM #68
I posted on the site you told me 71V153 asking about the reed stuffers. Someone said that fuel line can do the same job ??
Any thoughts
06-19-2017, 05:09 PM #69
Fwiw the Baja ran 54.9 with a '86 90. And 62.9 with a '83 140.
Best with the "7 1/2 paged" frankinrude motor so far's 66.7.'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
06-19-2017, 05:29 PM #70'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
06-19-2017, 05:34 PM #71
There was somebody somewhere threatenin to start makin em. All ya'd need'd be an intake manifold'n reed cage. And some knowledge of injection molding?
06-19-2017, 06:52 PM #72
Wow.... My bet is I can put a jack plate on that boat and a decent steering system and get 50 out of it easy if it has a straight solid hull free of hooks, etc. Chine walk at 40?
You are putting the "carriage in front of the horse".
Originally Posted by 71V153
Originally Posted by flabum1017
I still have a '79 100hp high ring OMC that has never had the heads off. Just over 48 mph GPS with 420# of persons, an ice chest with a case of beer, and 18 gallons of gas. With nothing in the boat but me and a 6 gallon can, you had to "get up on the wheel".
This has been entertaining. BTW the 9 pages was designed for the V6, NOT THE V4!!!
Carry on.
The Starcraft...Last edited by Forkin' Crazy; 06-19-2017 at 06:57 PM.
06-19-2017, 08:40 PM #73
06-19-2017, 08:45 PM #74
06-20-2017, 03:06 AM #75
[QUOTE=Forkin' Crazy;2963877]Wow.... My bet is I can put a jack plate on that boat and a decent steering system and get 50 out of it easy if it has a straight solid hull free of hooks, etc. Chine walk at 40?
What Jack Plate with what settings. My build is for the winter but if i can put on a Jackplate just now then tell me which one and with how much set back ?
Need help removing lower unit on johnson 85hp
By faster100 in forum Technical DiscussionReplies: 16Last Post: 06-17-2017, 03:48 PM -
Wanted: MINT 1978 or 1979 Johnson 85HP cowl
By FlowMaxx in forum Parts WantedReplies: 2Last Post: 09-19-2014, 03:08 PM -
OMC Tech: '77 85HP Trim help needed
By turbotadd in forum Technical DiscussionReplies: 4Last Post: 05-15-2009, 09:39 PM -
85hp johnson heads off
By phillnjack in forum Technical DiscussionReplies: 1Last Post: 04-05-2005, 05:34 PM
