Results 16 to 30 of 182
06-18-2017, 02:42 PM #16
Btw don't do anything to the ports besides squaring them up.
06-18-2017, 02:43 PM #17
The what heads should i look for ? I read somewhere that the heads can be skimmed but it makes very little improvement in compression. There are heads that have some kind of edging ??? or something in the squish band tht does the job ??? Am i right in thinking that i should also stick to the same year for the parts ???
06-18-2017, 02:48 PM #18
Almost forgot. On the 140's the base of the exhaust bridge is sawed/ground off. Besides that the blocks are the same.
06-18-2017, 02:50 PM #19'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
06-18-2017, 02:59 PM #20
Would heads from a 1984 140 fit ?
06-18-2017, 03:01 PM #21
What I meant about the exhaust chest:
06-18-2017, 03:02 PM #22'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
06-18-2017, 03:10 PM #23
Fyi in 1985 that motor was detuned to become the prop rated 115. After everybody finally agreed to go from BIA(crank rated) hp, to prop rated.
06-18-2017, 03:10 PM #24Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
It's been many many years but a bud did have a 140 block next to an 85. I recall us talking about the differences in the ports, size?
06-18-2017, 03:32 PM #25
Cool i understand now
06-18-2017, 03:34 PM #26'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
06-18-2017, 03:36 PM #27
Only difference being the exhaust cut out.
06-18-2017, 03:38 PM #28Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
That 85 must be 77 lol
06-18-2017, 03:40 PM #29
I think the hardest part to get here in Scotland will be the "Bubble butt exhaust manifold and chest."
But i can always look on ebay USA and hopefully find them
What does the cut out do for the flow ?
06-18-2017, 03:42 PM #30
Lost me on that one FMP
Need help removing lower unit on johnson 85hp
By faster100 in forum Technical DiscussionReplies: 16Last Post: 06-17-2017, 03:48 PM -
Wanted: MINT 1978 or 1979 Johnson 85HP cowl
By FlowMaxx in forum Parts WantedReplies: 2Last Post: 09-19-2014, 03:08 PM -
OMC Tech: '77 85HP Trim help needed
By turbotadd in forum Technical DiscussionReplies: 4Last Post: 05-15-2009, 09:39 PM -
85hp johnson heads off
By phillnjack in forum Technical DiscussionReplies: 1Last Post: 04-05-2005, 05:34 PM
