Results 1 to 2 of 2
06-11-2017, 10:54 AM #1
WTT: 2007 Custom Built Pro Street Chopper
Wanting to trade my Pro Street Chopper built in 2006 and registered in 2007 for a 20' or less Mercury powered race/speed hulled boat. Email captrivers@hotmail.com or 225-290-0560 for more info and any interest.
Kraft Tech Dagger Rigid 250mm frame 38 degrees of rake 2 downtube stretch 5 backbone stretch
Big-Un chrome front-end assembly 4 over stock
5 stretch aluminum pro street gas tank
60 spoke 21 x 2.15 front wheel
Avon Venom 90/90H-21 front tire
Rear 11 Wild Card one-piece fender
Pro-One rear fender strut
60 spoke 18 x 8.5 rear wheel
Avon Venom 250/40VR-18 rear tire
S&S 103 Sidewinder with less than 500miles on +.10 over bore, NEW pistons and rings, the rings are still cutting-into the cylinders.
Recent install of a Dynatek D2KI-5P Kit (2Ki ignition & DC6-5 Twin Fire II Coil)
ForceWinder air filter
JIMS Oil Pump
JIMS Tappets
JIMS Tappet Blocks
JIMS Gear case Cover
JIMS Roller Rockers
Exotic Choppers DECEIVER pipes
Arlen Ness 5 Ύ stretched bullet headlight
Danny Gray alligator custom wrapped seat
Choppers Inc WHISKY bars
Choppers Inc risers
Choppers Inc oil plug
Pro One RH mirror
Jay Brake front caliper & mounting bracket
Jay Brake front master cylinder
Jay Brake forward controls & passenger pegs
Jay brake rear caliper and bracket
Jay brake clutch lever and grips
BDL belt drive BDL 32T trans pulley and BDL 70T rear pulley
Break-in miles only on:
Bored cylinders .010 and installed S&S pistons and rings
Custom Chrome 5 speed tranny - installed a Baker anti-over shift ratchet pawl, shift arm seal, trans shaft seal and engine main shaft seal with Bel-Ray Big Twin trans fluid 75w-140Luck is the Residue of Design........
06-11-2017, 11:18 AM #2
Sent you a pm.
RockTeam Junk
Custom Built MKA 1919
By HStream1 in forum Non-Marine ItemsReplies: 0Last Post: 12-01-2016, 08:18 AM -
Custom built trailer for hydrostream
By WhiplashedToyota in forum Tow Vehicles and TrailersReplies: 0Last Post: 02-06-2015, 09:12 AM -
Just got some new custom trailers built
By WILDMAN in forum General Boating DiscussionReplies: 8Last Post: 09-20-2012, 11:06 PM
