Results 1 to 4 of 4
Thread: Set back vs shaft length
06-09-2017, 10:24 PM #1Junior Member
- Jun 2016
- Eastern NC
- 24
Hello to all this is my first post on here. Looking for some knowledge on the advantages of a 20" shaft motor on a 12" jack plate vs just running a 25" shaft on the transom. I have a 1987 21' Olympia, currently the boat has a 175hp fast strike Johnson that is on a 6"CMC manual bracket. I can tell that the motor is a little to high
or not far enough back. Depending on how you look at it. The boat on gps will do 52mph, which I think is pretty good for an ole tired Johnson. I would like to eventually put a 300xs on the boat. But don't know if I should go with a 25" shaft or a 20" shaft on a 12" set back. Other than being able to run in shallower water what are the advantages going the 20" route? Thanks for any input.
06-09-2017, 10:40 PM #2Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,645
- 606
- 923
- 1699
- 7152
- 3 Post(s)
The lower you can get the weight the better off you will be. When boats start to run above 70 mph CG becomes an important part of the equation.
06-09-2017, 10:50 PM #3Junior Member
- Jun 2016
- Eastern NC
- 24
Thanks. I didn't even think about the CG aspect of it. Am I wrong thinking that the longer shaft would have more leverage to carry the bow better? This is my first outboard, I've got more experience with BBC sport boats.
06-10-2017, 07:54 AM #4
Welcome to S&F and be prepared for some great "schoolin"! I learn something on here every day. I agree with Joe completely and a beleiver in shorter mids with setback. Gary
Want To Buy 3.0 LH sporty 1 piece or 2 shaft length no matter... 1.62 small shaft
By vw-nut in forum Lower UnitsReplies: 0Last Post: 10-31-2015, 06:58 PM -
15 Allison Shaft Length ?
By littledcsrodshop in forum Technical DiscussionReplies: 9Last Post: 07-30-2014, 12:44 PM -
O/B shaft length
By retro rocket in forum Technical DiscussionReplies: 2Last Post: 12-13-2008, 03:27 PM -
shaft length
By levi beard in forum Technical DiscussionReplies: 0Last Post: 06-11-2007, 05:30 PM -
Shaft length??
By Bill H in forum Props, Setup, and RiggingReplies: 0Last Post: 12-11-2004, 11:45 AM
