Results 76 to 85 of 85
06-16-2017, 05:09 PM #76Member
- Jun 2017
- LI
- 57
06-16-2017, 09:24 PM #77
And vacuum bagging ?? you don't need the maximum of 14.7 psi !, possible less than 25% 0f this is even more than you would need!! Using lots of weights are the last straw and you have to cover the total surface as in 100% and have no gap's any where but that is real hit and miss vacuum is much much better And if you fitting strips of bevelled foam around the perimeter that needs to be done and sucked down together all at the same time !!!!Any surplus resin and what ever will likely fill all and any gaps there maybe and the vac bag will have made a smoothing out of such places !.
What glass you anticipate covering it with and finishing with ?????
My suggestion is to lay a csm 450 over the core and then a 1708 with the csm attached facing up !.
The csm under is a cushioning layer for the 1708 to adhere to the core much better . All this need to be done at the same time and rolled out flat and even as this will be a done and finished all at the same timeLast edited by tunnels; 06-16-2017 at 10:35 PM.
06-24-2017, 07:03 PM #785000 RPM
- Jun 2001
- 211
What is the color of this boat, I own one 20 years ago and it had bottom problems/?
06-27-2017, 07:07 AM #79Member
- Jun 2017
- LI
- 57
06-27-2017, 07:28 AM #80Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Hows the boat project coming?
06-27-2017, 10:08 AM #81Member
- Jun 2017
- LI
- 57
06-27-2017, 10:26 AM #82Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
It's good to let it get good and dry anyhow. Prep is the most important part, take your time. Glassing goes fast...
06-27-2017, 08:13 PM #83Member
- Jun 2017
- LI
- 57
Some pics....
06-27-2017, 10:19 PM #84
looking at the disc you have on that grinder its no wonder its taking time and producing so much fine dust 16 grit is best quickest and makes a better job !
Next question where are you intending to lay the core ??? yOU DO REALISE THAT WITH ALL THOSE STRAKES ITS NO WONDER THE HULL BOTTOM FLEXES UP AND DOWN !!SO EVEN WITH CORE ON TOP OF THE FLAT AREAS ITS STILL GOING TO FLEX JUST AS BAD AS BEFORE and glassing with lots of layers isn't going to help much either !!!!
Strakes are and always have been potential weak points where the glass bends on the 3 corners of each strake so the more strakes the easier the hull bottom moves and bends in those places !!.Plus they are favourite places for poor laminating ! also have bubbles and resin rich and places the delaminate very easily so even more weaknesses !! bad design for sure !Last edited by tunnels; 06-28-2017 at 03:01 AM.
06-28-2017, 06:48 AM #85Member
- Jun 2017
- LI
- 57
I cannot do anything about the original hull design so I will do my best to reinforce it.......My plan is one layer of 1708 in the pad and about 6 inches up the side of the pad then another layer of 1708 over the entire hull. I will focus on each strake trying to ensure no bubbles. Core will be bedded on the pad and then on each side of the pad as originally done by the factory. In the pad the Core will run from Transom to Bow. Should I fillet the core to the corner of the pad for added strength?
However, before I can do any of this, I have to fix Multiple LONG routed out gaping holes within the hull (Not to mention a few grinding mistakes I made along the way!!!). You can see them in the pics. I should be able start glassing this week.....IF , I have time.....
63.1 MPH Valero Bowrider
By ozziffied in forum Props, Setup, and RiggingReplies: 7Last Post: 09-28-2009, 09:56 PM -
89.9 Gps- Valero Yt Bowrider!!
By 200valeroyt in forum Props, Setup, and RiggingReplies: 24Last Post: 08-19-2008, 08:47 PM -
Valero yt bowrider or Allison GT-20
By Southern Outboard in forum Technical DiscussionReplies: 0Last Post: 02-09-2003, 05:55 PM
