Results 31 to 45 of 85
06-12-2017, 04:44 PM #31Member
- Jun 2017
- LI
- 57
It was available and supposed to be really strong. Only paid 125.00. Never used it before but then again i never recored a stream before. Any particular issue with it?
06-12-2017, 05:21 PM #32Member
- Jun 2017
- LI
- 57
This is the product
06-12-2017, 07:38 PM #335000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
This appears to be the same type of material that I have used on my Shadow. However, I bought pre-laminated panels. Mine has no hull coring but I've been using 3/4" for decking, stringers, knees, etc. Mine came from Carbon-Core. I don't know of any reason that it wouldn't make a good hull core material. Glass and resins seem to adhere well.
06-12-2017, 09:39 PM #34
06-13-2017, 05:14 AM #35Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
What is the density of the core? I don't see that used very often. And as for supporting the hull, lots of guys have left the boat on the trailer and just added some 2x4's to the frame to give a straight and level support for the bottom. Avoid putting any support at just one point. Spread out the load as much as possible fore and aft. Last 6' is the most important. They usually hold their shape fairly well with this. If the boat is to be on the ground, same thing, make a frame for it to sit on using wood.
06-13-2017, 09:26 AM #367000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Im not saying its the same brand but we use something very similar called nidacore made by 3M. Its a great product. It is super lite and conforms well when its raw, can cut it with a razor knife if need be. I believe that its comparable to 5lb foam core. Nida states that by doubling the laminate thickness increases stiffness by 7x. When sealed on both sides acts as flotation, needs to be treated like foam, wont hold a screw so plan out where things go and add solid core where things need to be screwed in. As a hull core it works great so go ahead and use it. Although 125$ seems a bit much for it. The cut edges are a bit tough to glass seeing as how the honeycomb is open when its cut. A small fillet of foam or some putty makes glassing the raw edges easier.
06-13-2017, 09:44 AM #37
A band saw with a fine tooth blade is best for cutting any core be it Balsa , any of the foams, regardless of density and also nida core ! I have asked but had no reply to see if this product is foam filled
Have always used a bands saw to the bevelled edge is easy to shape and carefully with a grinder a radius can be formed Rather than using the dreadful putty any where !.Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
06-13-2017, 10:05 AM #38
06-13-2017, 10:21 AM #39Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
06-13-2017, 11:08 AM #40Member
- Jun 2017
- LI
- 57
I do not believe the comb is completely filled. No, I have not vacuum bagged before so based on your comments, I spoke to the distributer...he said that while vacuum bagging is preferred, there is absolutely no issue setting it in bedding compound....just have to make sure it lies flat with no air pockets. He suggested using sang bags as they will distribute weight.
He did say to be careful with the edges when cutting however...
06-13-2017, 11:10 AM #41Member
- Jun 2017
- LI
- 57
06-13-2017, 11:18 AM #42Member
- Jun 2017
- LI
- 57
I have to edit that quote...it is $225 for the entire amount (8 4x2 panels). I thought that was a great price considering I was getting quotes of up to 4x that much for high density PVC.....
The edges were a concern of the distributor as well.....Thank you for the advice
06-13-2017, 11:18 AM #43
I think our boats are twins! I posted a few pics of the finished product in the Power Tour thread.
06-13-2017, 11:23 AM #44Member
- Jun 2017
- LI
- 57
06-13-2017, 11:38 AM #457000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Im sorry tunnels, what part of (the honeycomb is open when its cut) was misleading? Its composed of (hollow) honeycomb structures. So no its not full of foam, its hollow in the middle.
63.1 MPH Valero Bowrider
By ozziffied in forum Props, Setup, and RiggingReplies: 7Last Post: 09-28-2009, 09:56 PM -
89.9 Gps- Valero Yt Bowrider!!
By 200valeroyt in forum Props, Setup, and RiggingReplies: 24Last Post: 08-19-2008, 08:47 PM -
Valero yt bowrider or Allison GT-20
By Southern Outboard in forum Technical DiscussionReplies: 0Last Post: 02-09-2003, 05:55 PM
