Results 1 to 4 of 4
05-26-2017, 02:46 AM #1Member
- Mar 2015
- Harrison, TN
- 30
1986 2.0 135 Black Max final gear ratio?
I am out of town working and trying to figure out what my lower unit drive ratio is. I have a standard 1986 135 Black Max 20".
I have my serial number will that help me at all I know it tells me the year 0A980754. Trying figure out if it is 1.87 or 2.00 to 1?
Any help would be greatly appreciated
Thanks
05-26-2017, 07:03 AM #2
Set your flywheel at TDC and mark your prop and gearcase. I run a single piece of tape across the hub and gearcase and cut the tape with a razor knife. Rotate engine 2 turns. If the tape lines back up you have 2 to 1. If the tape is past the mark you have a higher (numerically lower) ratio.
Don't know how long you're out of town but that's the most reliable way imo. You never know if it's been tampered with, this way you'll know for sure.Last edited by cyhuff; 05-26-2017 at 09:19 AM.
05-27-2017, 07:54 PM #3Member
- Mar 2015
- Harrison, TN
- 30
05-30-2017, 09:50 PM #45000 RPM
- May 2017
- US / NC
- 131
At that time most came with the 2.0 (135-150 Hp )
Mercury Tech: ratio for a 1979 black max 200????
By evol805 in forum Technical DiscussionReplies: 3Last Post: 05-17-2009, 07:35 AM -
Final had a upper gear failure after 4 years
By RLC PE in forum General Boating DiscussionReplies: 77Last Post: 02-22-2009, 10:45 AM -
1986 black max 175
By 87 concord in forum Technical DiscussionReplies: 1Last Post: 11-02-2007, 09:24 PM -
1986 200 Black Max question
By Phil L in forum Technical DiscussionReplies: 2Last Post: 04-25-2005, 05:39 PM -
1986 Stratos VT Rocket 175 black max
By Delta Breeze in forum General Boating DiscussionReplies: 4Last Post: 08-28-2004, 09:25 AM
