Results 1 to 3 of 3
    May 2005
    Louisiana
    300 Verado 2007 .. # 6 cylinder hydro locked with fuel
    Ok we are going out ... And barely hit a tree stump on the port motor ....
    Engine then dies .... After checking fuel pressure ... We only had 15lbs ... Then after cranking the motor locked up ... Upon removing the spark plugs #6 cylinder was full of fuel ... Enough to lock the motor ?
    What could cause # 6 to fill up with fuel ... I read there might be a defective vacume line in the fsm .... That ruptured causing the cylinder to fill with fuel ?
    Any advice will help ... I have not removed the FSM yet ... But did check all injectors and the spray pattern is fine .... Thanks in advance ...
    Aug 2015
    NE Tennessee
    Don't know much about the Verado, but be careful cranking a motor that hydro locks, fuel or other. On car/truck motors it is possible to bend rods that way.
    If it's fuel injected, a leaky injector ( one that won't close ) you can fill up a cylinder in just a few key cycles ( again car/reuck EFI motors )
    HTH
    Could the stump have stopped the prop and engine at the instant the injector was filling #6 and the system was slow to respond to the forced stall and kept squirting because the degrees of rotation halted? Maybe needs a reset after impact, if that's possible.
  1. 2007 Mercury Verado 275
    By JUPITER PULSARE in forum Outboard Engines
    Last Post: 05-03-2016, 04:58 PM
  2. Lost fuel pressure ,fuel coming out of number 6 cylinder
    By big poppa pump in forum Technical Discussion
    Last Post: 09-07-2015, 06:24 PM
  3. Mercury Unveils New Verado 135, 150, and 175 HP 4-Cylinder, Supercharged Engines
    By Scream And Fly in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 03-27-2005, 10:57 PM
  4. Mercury Unveils New Verado 135, 150, and 175 HP 4-Cylinder, Supercharged Engines
    Last Post: 02-19-2005, 02:29 PM
