Results 1 to 6 of 6
05-24-2017, 10:41 AM #1Junior Member
- May 2017
- Michigan
1995 2.5 promax oil alarm problem
Looking for some wisdom.......my oil alarm contines to beep, I have replaced the sensor module, sensor in the oil reservoir checks out with ohm meter....I removed the oil pump used a screw driver in the baring assembly and manually turned the crank , the drive gear on the crank does not appear to be worn.....is this gear steel or plastic on this year model.....the senor on top of the oil pump is in question but everyone I spoke with never seen one go bad, maybe baring assembly with magnet is worn enough to cause a probem...pump is pumping oil so now I am lost....any suggestions
05-25-2017, 06:57 AM #2
Yeah, pull it all off and throw it in the trash, then premix....you will be glad you did. Drive gear on the crank is plastic. Those are great motors but the oil injection system...not so much.
Go Time
26 Regulator twin 250 EFI
W2F a V-King liked this post
05-25-2017, 07:01 AM #3
If you must keep it, run the engine on premix and do the volume out put check in the service manual to confirm its operating properly first.
Go Time
05-25-2017, 07:07 AM #4
I would also suggest to remove it and premix. Pretty simple then, if it is running it will be getting lubrication.
Even though that plastic gear is stout, it is no match for a metal pump gear.
05-25-2017, 07:10 AM #5Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Sensor magnet in oil pump does have to be oriented in the correct direction. Can't say the correct orientation w/o a manual. Just a guess.
05-25-2017, 06:40 PM #6Junior Member
- May 2017
- Michigan
Resolved my problem, It was a bad oil sensor above the pump...Back in action for a minute.......Thank's for all the input guy's
OMC Tech: 1995 E150GLEOM VRO alarm vacuum line question
By KSRanger in forum Technical DiscussionReplies: 1Last Post: 07-08-2013, 10:25 AM -
By KSRanger in forum Technical DiscussionReplies: 2Last Post: 06-23-2013, 10:59 PM -
alarm problem
By vdrivenman in forum Technical DiscussionReplies: 6Last Post: 06-11-2007, 08:48 PM -
1995 200hp Alarm?
By 86vintage in forum Technical DiscussionReplies: 2Last Post: 10-06-2006, 05:49 PM -
1995 200 Yamaha Pro V Overheat Alarm?
By hullbilly24 in forum Technical DiscussionReplies: 2Last Post: 03-22-2005, 10:00 PM
