Results 1 to 15 of 18
Thread: Changes to Promax water routing
05-23-2017, 09:24 PM #1
My 2000 Promax has no hose running from the top of the block to poppet. I have seen others run that way. The thermostats dump port side to telltale, starboard side to the adapter.
My question is why did Mercury start installing plugs? Wouldn't the poppet hose to the top of the block help with warming the block?
Trying to help get to temp in Michigan cold water. (New thermostats, impeller, and poppet kit)
Kurt
1992 Allison XTB 21 / 225 Promax
05-24-2017, 07:38 AM #2
I would put it back stock.
Go Time
26 Regulator twin 250 EFI
tux974 liked this post
05-24-2017, 09:40 AM #3
05-24-2017, 10:03 AM #4
I dont think they ever came that way, but I've been wrong before. The normal hose routing for the steel 2.5s is the same on all production motors. One hose from poppet to top of block and a hose from stbd thermostat to port then to tee that goes to tell tale & adapter plate.
Go Time
05-24-2017, 10:08 AM #5
All 3/8 i.d. hose?
05-24-2017, 11:50 AM #6
That's what I use on mine iirc
05-24-2017, 12:43 PM #7
The tell tale maybe 5/16, but everything 3/8 will do it. Make sure you have the tell tale nipple on the end. The small hole in it helps.
Go Time
05-24-2017, 04:56 PM #8
It makes me question why they changed it? It's plumbed like a 225x. I had one that was like that. Maybe because it is a 2000, close to the end run of production?
05-24-2017, 05:00 PM #9
The one i had like that was a 2000 also
05-24-2017, 07:10 PM #10
My factory service manual shows the 2000 model plumbed the traditional way. The poppet to the top of the block, starboard to port to the adapter with a tee to telltale.
05-25-2017, 05:35 AM #11
W2F a V-King thanked for this post
05-26-2017, 07:30 AM #12
05-26-2017, 07:59 AM #13
Hose size?
05-26-2017, 09:03 AM #14
3/8 on all three nipples on top tee. Bottom tee is 3/8 from top tee & to adapter, 5/16 to tell tale.
Go Time
05-26-2017, 01:04 PM #15
OMC Tech: Water Hose Routing
By Jim_Pat in forum Technical DiscussionReplies: 2Last Post: 06-21-2014, 05:11 PM -
Mercury Tech: Routing water pipes
By 0081 in forum Technical DiscussionReplies: 39Last Post: 07-17-2013, 12:26 AM -
Water hose routing quetion??
By BIGLAY5150 in forum Jet Boats, V-Drives and Stern DrivesReplies: 5Last Post: 10-12-2007, 10:28 PM -
Low water pickup hose routing
By nacimientobound in forum Technical DiscussionReplies: 0Last Post: 06-26-2005, 12:43 AM -
Water Pee Hole Routing ?
By Carter Powell in forum Technical DiscussionReplies: 0Last Post: 11-02-2003, 06:53 PM
