Results 1 to 3 of 3
05-22-2017, 11:58 AM #1
SOLD - 26p Bravo 1's, L & R, blueprinted with CNC cut PVS holes (can be plugged)
SOLD!
Up for sale is a pair of 26p Bravo 1's. Both props are in great shape, with a 8/10 rating on the S&F scale. Freshwater use only - until the boat went to FL, and it got dipped twice.
Props were balanced and blueprinted by Kevin @ R&R Prop Shop. Never damaged/repaired or welded on. He also used his CNC machine to cut Mercury specific PVS ventilation holes. 4 holes in each prop. These holes helped get my Scarab out of the hole. Because they are PVS spec, you can purchase PVS plugs and different size orifices should you not need the holes, want to neck them down in size, or plug them completely.
$650 for the pair plus shipping. Will separate if the left goes first. $350 each plus shipping. Located in Port St Lucie, FL for pickup.
Pics to come. Call Keith @ 702-324-4449 or email keith@stvboats.comLast edited by STV_Keith; 06-19-2017 at 06:11 PM.
Keith-
06-02-2017, 05:07 PM #2
Pictures...
Keith-
06-08-2017, 11:01 AM #3
sold!
Keith-
29 bravo xs 8 pvs holes
By bado300x in forum PropellersReplies: 2Last Post: 09-28-2016, 05:48 PM -
28 Bravo 8 PVS holes
By DannyEllrich in forum PropellersReplies: 0Last Post: 09-17-2016, 03:16 PM -
3L TorqueMaster housing with some holes plugged
By Air&Sea in forum Lower UnitsReplies: 24Last Post: 01-28-2016, 11:08 AM -
plugged intake holes
By dschifan in forum Technical DiscussionReplies: 7Last Post: 05-15-2006, 03:41 PM -
Plugged up all CLE holes but one, still can't make any heat
By WATERWINGS in forum Technical DiscussionReplies: 15Last Post: 11-19-2003, 12:56 PM
