Results 1 to 15 of 27
    Fresh 2.4 dont want to run under 3000 rpm
    Ran this mota on the boat for 1st time yesterday and it dont want to run anywhere under 3000 rpms. Its a fresh rebuild with square port pistons,vertical front swapped to 5 peddle front shaved 0.50" with fiber reeds, wh20 carbs with 90 and 92 main jets to start 32cc heads timming at 24* .
    Ran all fine on the hose for the past few weeks. But once in the water it didnt want to throtle up slowly and take off. Once it does get up over 2500-3000 it really smooths out and wants to run good and hardwith no problems at all.
    This is a 1st time out on the Viking and a newly rebuilt motor and so plenty of tweeking to get it to where it needs to be.
    So any and all sugestions are appriciated.
    Where do i start?
    I guess my 1st step would be to seal up this hole in the 2000ish w.5L cowl i swapped from the clamshell cowl. Because i see where water has been mixing with the oil around the carbs. Also mite be shorting out a couple of plugs with the water??
    Attached Thumbnails Attached Thumbnails 1495382238265468042856.jpg   1495382332936-711166080.jpg   14953821850201612962011.jpg
    Pekin, IL
    Could be low speed winding in the stator. I know when the high speed winding goes out it won't rev above 3000. Just a thought.
    Rock
    Team Junk
  4. Thanks roadkill636 thanked for this post
    Likes BUZZIN' DOZEN, tux974, Scream And Fly liked this post
    Moline,Ill
    I was just gettin' ready to say low side of stator
    is gone
    Dec 2011
    Ludington michigan,on the shore
    X3^^^
  7. Thanks roadkill636 thanked for this post
    I wasn't getting ready to say nuthin
    But if I was, I'd say I'd say stator.
    I wouldn't worry too much about the plugs getting wet. I had a thermostat dump hose split on me once and it was drowning the plugs but it ran just fine.
  9. Thanks roadkill636 thanked for this post
    May 2014
    Livingston, Louisiana
    I give another vote with a low side winding on a stator also. Since it idles on hose. Take your volt meter while it's idling and check the red wire and the red / white wire (Red on one and red/ white on the other switch box) these are your two low side winding power supply to each box. They should have a minimum of 20 volts on these wires at idle, if either one doesn't or if one is a considerable difference than the other your stator is bad.
  11. Thanks roadkill636 thanked for this post
  12. #8
    Ok. Found the timming screw all the way retarted. I oviously forgot to tighten the lock nut when setting the idle. And with that the butterfly's were part open also the cam is already tuching the roller. And #1 bleed hose was off and the the old fuel pulse valve on #5 was un capped. Started rite up and idled good and areved up good.
    Checked voltage on red/white wire while running from stator to pack and was getting 1.6v... maybee im not pro ing the correct one.
    Attached Thumbnails Attached Thumbnails 1495417772496-1300418648.jpg   14954177405991615440172.jpg
  13. #9
    May 2014
    Should be a red one in same place on other box, check it for reference. They should also ohm from 27-55 ohms to ground unplugged from switchboxes.
    You can't read any voltages on an outboard ignition without a dva meter.
    Aug 2015
    NE Tennessee
    Might want to ditch that timing control box ( idle stabilizer.. ) too.
    Some guys like em and leave them....It's the first thing I get rid of on my motors..jmo.
  16. #12
    Quote Originally Posted by W2F a V-King View Post
    Didnt I? Isnt it gone on the left side? Or did i trash the wrong component?
    TX......somewhere?
    Quote Originally Posted by roadkill636 View Post
    right conditions have seen carbs and reed plate completely covered with condensation/sweat..... from jus being light ta very heavy.........
  18. Thanks roadkill636 thanked for this post
  19. #14
    Aug 2015
    NE Tennessee
    Not sure which one you removed. If your not using the oil injection system, no need for that black box either.
  20. #15
    TX......somewhere?
    it would be tha one that had three wires.. red/white, white/black, black
  21. Thanks roadkill636 thanked for this post
  1. Fresh 2.5 carbed, complete with fresh sportsmaster
    By tkutner1 in forum Outboard Engines
    Last Post: 03-14-2016, 03:43 PM
  2. 3000 surging
    By ares650 in forum Technical Discussion
    Last Post: 05-29-2004, 08:30 AM
  3. 3000
    By WILDCAT2.5 in forum The Scream And Fly Lounge
    Last Post: 10-08-2002, 03:53 AM
