Results 1 to 8 of 8
05-19-2017, 08:21 PM #15000 RPM
- May 2005
- Louisiana
- 196
New Mercury Verado Helm getting hot and making hissing sound ...
Can someone give me advice why this new helm is getting real hot and making a hissing noise ? It's a not a long run , not more than 10ft ... I read that it might need a
A cooler ? The question is its less than month old and now is the helm damaged ?
Thanks
05-19-2017, 11:12 PM #25000 RPM
- May 2005
- Louisiana
- 196
Bump
05-19-2017, 11:44 PM #3
Should not be getting too hot and does not need a cooler. Look for restrictions making the pump work hard. Kinks in the hoses etc. Assuming you are using the right oil and is filled and properly bled.
05-19-2017, 11:57 PM #46000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Helm mounted in the console? They don't like short runs of hose. They actually say to run long hoses even if not needed to help cool the fluid. Coil them up somewhere, added volume and some cooling effect.
05-20-2017, 10:16 PM #55000 RPM
- May 2005
- Louisiana
- 196
Do u think the noise now is a damaged helm ?
05-21-2017, 05:01 PM #66000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
You didn't do it any favors. It might be ok. How's it sound when cold?
05-21-2017, 05:12 PM #75000 RPM
- May 2005
- Louisiana
- 196
Well ill one we paid a dealer to install , so it was not our fault of they installed not enough line to dissipate the heat ! Second of these lines are sold by Mercury but are sold in short lengths , should they not have technical note telling the tech the minimum requirements for hose runs ?
The noise is not as loud when cold but as it heats up , the noise gets louder for sure...
I feel that either the oil is foaming with heat or there is damage to the helm ? But maybe the oil is now broken down because of the excess heat ? Just asking for advice , I do have a guy that has access to Mercury tech line .... Thanks
05-21-2017, 05:24 PM #86000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
It's one those you can but you shouldn't. I won't install short lines from the helm to the pump. I *think* they may have released a service bulletin but I do know it was discussed at school in the verado class. It's just the return that needs to be longer.
If it was purchased and installed by a dealer its covered under warranty. Take it in. You can also call Mercury's consumer line. They are very helpful.Last edited by RSWORDS; 05-21-2017 at 05:31 PM.
Bosch 983 making navigation sound
By greggeorge in forum Technical DiscussionReplies: 0Last Post: 06-12-2016, 09:36 AM -
Alternative steering helm to Mercury Verado power assisted steering
By Toffen in forum General Boating DiscussionReplies: 17Last Post: 12-12-2015, 04:15 PM -
Mercury Tech: Merc 92 2.5 making weird clicking sound
By marcw31 in forum Technical DiscussionReplies: 1Last Post: 09-01-2008, 08:05 AM -
hissing sound with oil drip
By illMATTic in forum Technical DiscussionReplies: 3Last Post: 05-26-2005, 02:23 PM -
CLE making whining sound
By david laser86 in forum Technical DiscussionReplies: 5Last Post: 10-25-2004, 03:12 PM
