Results 1 to 6 of 6
Thread: 225 optimax problem
05-18-2017, 10:41 AM #1New Member
- Dec 2016
- Westchester ny
225 optimax problem
Brand new 225 2015 pro xs already been towed in twice not even 3 hrs on the motor originally was not starting turned out to be a battery issue put 2 new 1000cca batteries in and fired right up thought that was the fix then died again rewired the perko switch stated right up this morning went to take it for a run motor died in the harbor . any ideas as to what is going on hopefully something simple definitely sounds electrical i know these things are very sensitive to voltage drops, im getting good voltage to the batteries when running
05-18-2017, 11:12 AM #2Screaming And Flying!
- 14,703
- 380
- 1280
- 5599
- 10936
How old is the key switch? How about the kill switch? Harness connector on motor tight and locked?
05-18-2017, 11:24 AM #3New Member
- Dec 2016
- Westchester ny
It is an older key switch it was from a 2006 Mercury 150 EFI
05-18-2017, 11:42 AM #4Screaming And Flying!
- 14,703
- 380
- 1280
- 5599
- 10936
Could very well be the problem. They wear from use and get corrosion internally. You might try and start the motor and then wiggle the key slightly to test. Not a good test though. I would just replace it since it is 11 yrs old...It is an easy thing to do...One less thing to fail, even if it is not the problem.
05-18-2017, 03:26 PM #5New Member
- Dec 2016
- Westchester ny
Was a loose wiring harness to crank position sensor clicked it back together all good thanks for the help I may still change ignition to be safe
05-18-2017, 03:39 PM #6Screaming And Flying!
- 14,703
- 380
- 1280
- 5599
- 10936
That's a good find. Stuff like that can be a real pain to pin point.....
Problem with my optimax
By Big Rude in forum Technical DiscussionReplies: 5Last Post: 11-05-2012, 09:39 AM -
problem optimax 200
By nikos in forum Technical DiscussionReplies: 1Last Post: 12-30-2011, 10:00 AM -
Mercury Tech: 150 Optimax problem
By Black Lightning in forum Technical DiscussionReplies: 1Last Post: 06-14-2009, 08:32 PM -
'99 150 Optimax Problem
By an86carrera in forum Technical DiscussionReplies: 3Last Post: 08-19-2007, 12:46 PM -
Optimax problem
By FlatsMaster in forum Technical DiscussionReplies: 4Last Post: 12-17-2002, 05:56 PM
