Results 1 to 12 of 12
    May 2017
    Mount Sterling Kentucky
    Johnson GT200 Powerhead swap
    Calling all Johnson GT experts..
    I have an 89 GT200 (J200STLCEB) with a blown powerhead, the block is beyond repair. So, my only option is to buy a used outboard which will cost me nothing less than a small fortune, or buy a used powerhead to throw on my lower unit. I found an '87 GT175 powerhead for $450 in good shape, all it needs is a lower unit and the electronics. I was looking at the parts breakdown of these 2 engines and I see that some of the electronics on the gt175 are different from the electronics on mine. Would any of my electronics work on the 175? Would it be worth it to buy the electronics I need for the gt175?
    Sep 2015
    ∀ʇOsƎuNᴉW
    My 87 GT200 had bad stator, dripped and wrecked the timer so i bought a complete new system from CDI it says its for the 87 which it is but its really for the 88 up models. There are a few wires not needed and/or deleted but you now have a more modern set up. I went with the 8600rpm version, but the 6700 version you can save a few hundred bux. I'm no expert by any means but I am pretty sure the stators might be a different size because you have to make sure the stator is for the 86-87. Those are the special years for whatever reason. So i would say yes to your mess. let me rephrase this a bit. Thats if the 175 is the same as the 200 block and flywheel.
    May 2017
    Quote Originally Posted by Krazymaan View Post
    So are you saying I would be able to use my stator/cdi pack and everything else on the 175 if the block/flywheel is the same?
    Sep 2015
    ∀ʇOsƎuNᴉW
    Yes. But I'm not a professional but that's what I did and it works
    May 2017
    Okay, the guy told me it has the stator with it, I just don't know if I could use that stator that comes on it or if I had to use my stator
    Pickering and Lakefield, Ontario, Canada
    I'm pretty sure the 175 block won't fit onto your midsection. You'll have to change out the exhaust adapter, or put your gearcase onto the 175.
    That may not work either, because you are dealing with a crossflow engine with the 175, and the 200 is a looper. Seems to me these had different length drivshafts.
    May 2017
    Quote Originally Posted by 58Evinrude View Post
    Yeah, It looks like the exhaust adapter is different so I would have to buy that too.
    Whats wrong with your 89 block that its junk?
    May 2017
    2 of the crank bearings broke and wore out the journals so new bearings wouldn't even seat in my case
    Isnt the 89 a looper and the 87 a crossflow? Thought only loopers in 86 and 87 were 200hp.
    Thats right, he'd be farther ahead finding a 1988 or newer looper.
  12. #12
    May 2001
    The Villages, Florida
    86/7 V6 loopers in 200 and 225
    The 175 electronics will NOT work on any year looper, parts can be used but as a whole NO. Exhaust adapter is different, lower unit would work with a shift shaft change, drive shaft change in 92.
    88 up loopers use a different flywheel than 86/7 models.
  1. PLEASE HELP 90 johnson gt200
    By terry1 in forum Technical Discussion
    Last Post: 04-16-2016, 09:56 PM
  2. Johnson GT200
    By Don's AE21 in forum Technical Discussion
    Last Post: 01-20-2010, 12:30 AM
  3. johnson Powerhead Swap
    By decoy033 in forum Technical Discussion
    Last Post: 03-03-2009, 01:30 AM
  4. Powerhead Swap for 1989 Johnson GT 150
    By flaghappy in forum Technical Discussion
    Last Post: 11-02-2007, 03:23 PM
Bob's Machine
