Results 1 to 6 of 6
Thread: Using a 2.5 150 block
05-15-2017, 09:01 PM #15000 RPM
- Jun 2006
- Ramona Ca
- 270
Can you use a 2.5 150 rotating assembly and put all 2.5 200 external components on it? Thought everything inside is all the same. Not sure thanks.
05-15-2017, 09:06 PM #2
Sure can.
05-15-2017, 09:14 PM #3
You have a good 200 block with bad or no internals and want to put good internals you have from a 150? No problem. The porting is different in the blocks though as far as power goes. They also use different tuners, if you switching from 150 to 200 want to use the 200 tuner. The 150 tuner is a mile long,
05-15-2017, 09:56 PM #45000 RPM
- Jun 2006
- Ramona Ca
- 270
I have a 200 with a one low cylinder and a 150 ready with no externals. Still good to use them or is the porting going to be a big difference?
05-15-2017, 10:07 PM #5
It'll work with no problems, but you will loose some upper rpm power due to the less duration in the porting.
05-15-2017, 11:01 PM #6
if your boat is heavy and lots of gear ,live well's use 150 tuner , more low end power, 200 tuner use for lighter boat
250efi 3.0L block vs. 300x 3.0L block. What are the differences between the two?
By mac90sup in forum Technical DiscussionReplies: 26Last Post: 07-21-2016, 04:55 PM -
looking for an OX66 3.1 Vmax block 2000-2003 or long block, or HPDI 300
By dnelson964 in forum Engines WantedReplies: 2Last Post: 03-11-2016, 08:07 PM -
Mercury 2.5 200 block, (block is style that has the promax/260 type cut in exhaust)
By Phil Conant in forum Misc. Parts and AccessoriesReplies: 5Last Post: 08-10-2015, 04:25 PM -
Wanted : 300x block , windowed ok , bare block only
By OPTIXS in forum Parts WantedReplies: 0Last Post: 04-18-2014, 03:40 PM
