Results 16 to 30 of 46
05-19-2017, 08:20 AM #16
I actually started and was making pretty good progress, used the circular saw and made a grid pattern, and then used the air chisel to separate. I'm itchy as heck and grinding hasn't even started yet. I figured I'd throw out this PSA, if you don't know what you are doing, don't do it! U create more work to fix your screw up!
05-19-2017, 07:23 PM #17The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
Laminate the transom cores together first, on the ground with screws. You can remove them when cured. Template the transom shape you need. Transfer the shape & cut & trim the core.
W2F a V-King liked this post
05-19-2017, 07:25 PM #18The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
By the way. Make sure the boat is not twisted at all, and is properly supported squarely, before doing all this transom removal stuff.
05-19-2017, 07:33 PM #19The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
Quick & easy way to template anything, is to rip a sheet of doorskin on a tablesaw, lengthwise, into 1 1/2" to 2'' wide strips. Snap them over your knee to the desired length, while hot glue gunning them together, to the desired shape.
05-20-2017, 07:29 AM #20
I ended up pulling out the knees also, wanted to make sure everything was done properly. I have some cardboard here I'll use as a template, it's not a big transom, 3 ft by 18". Got the rest of it ripped out last night.
05-20-2017, 09:42 AM #21action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
05-20-2017, 12:45 PM #22
Pricey, but worth it. Cuts in hard to get places, and makes un-rotted core areas come up without hull damage because of the flat cut it makes. Not a replacement for a grinder, but for all else...
https://www.lowes.com/pd/DEWALT-29-P...ol-Kit/4780961James H. W2F a V-King... Want 2 Fly a V-King
mrcrsr liked this post
05-20-2017, 05:59 PM #23
First board is in, I used extra slow hardener(fiberglass supply epoxy), it's been about an hour and hasn't kicked off yet. I talked to a friend of mine who builds hi performance boats(everyone knows who he is, don't want to disclose it on here so he doesn't get hounded) but he told me to put the first (outer) board in, build the knees and mock it up, cut the outer board with slots in it for the knees, then glass it all in in one shot. That way there is never a chance of the transom getting ripped out. After that cures I'll extend the knees vertically to mate up to the splashwell delete, to build a box of sorts.
XstreamVking liked this post
05-20-2017, 06:01 PM #24action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
05-21-2017, 05:33 AM #25
Those are some really cool huge c-clamps. Never seen ones like you have in the center with that deep of a bite that goes almost to the bottom.
That baby's in there tight!!James H. W2F a V-King... Want 2 Fly a V-King
05-21-2017, 04:03 PM #26action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
05-21-2017, 04:35 PM #27action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
05-21-2017, 07:17 PM #287000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
very nice!!!
05-21-2017, 09:51 PM #29action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
05-21-2017, 09:58 PM #30action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
Coosa or Plywood for Transom Replacement
By maineidyl in forum Technical DiscussionReplies: 6Last Post: 12-01-2016, 07:13 PM -
Coosa Board for Transom and Stringers?
By tj309 in forum Fiberglass and Composites DiscussionReplies: 29Last Post: 08-26-2013, 01:05 AM -
How should I laminate plywood for the transom?
By ssv1761982 in forum Fiberglass and Composites DiscussionReplies: 14Last Post: 07-03-2009, 10:51 AM -
Coosa board for transom?
By strehl in forum Fiberglass and Composites DiscussionReplies: 17Last Post: 08-12-2008, 03:45 PM -
plywood for transom repair
By jag in forum General Boating DiscussionReplies: 16Last Post: 05-14-2001, 08:01 AM
