Results 16 to 30 of 76
Thread: Vector engine height?
05-12-2017, 08:20 AM #165000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I have one, I just need to hook it up. I tried the tan wire coming from the control box and it didn't work. I'm going to try the tan with blue stripe next. If it doesn't work I'll find somewhere to put a sender.
05-12-2017, 08:34 AM #17Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
At the motor end there should be a tan wire w/bullet connector from the sender and another one going into the harness. Connect them together. Tan wire at control should work.
05-12-2017, 08:44 AM #185000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I'll check it again. Thanks for the help!
05-12-2017, 08:49 AM #19Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Also check the over heat alarm to make sure it functions correctly. Ground the buzzer to confirm it works. Ground it at the motor to check it. Also could put the sender in some boiling water to confirm it all works.
05-12-2017, 11:16 AM #205000 RPM
- Jul 2014
- Mississippi
- 196
- 18
Is the buzzer in the control box?
05-12-2017, 12:39 PM #21Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
In the control box or on the harness under the dash....Small, black, about the size of a plastic bottle cap...
05-12-2017, 07:36 PM #225000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I measured my engine height using your method. Assuming the point of my nose cone is center of the prop shaft I had it about 1/2" above the bottom of the pad. I dropped it 1" so it's about 1/2" below the pad now and I'll go up from there. Could it being above the pad cause my handling problems ?
05-12-2017, 08:28 PM #23
If prop shaft is 1/2" below bottom now....try it from there....youll go up 1/4" at a time.....like he said above....DON'T ovetrim
05-12-2017, 08:39 PM #245000 RPM
- Jul 2014
- Mississippi
- 196
- 18
Could running it too high cause it to handle bad?
05-12-2017, 08:46 PM #25
If over trimmed ...yes!
But THE BOAT IS GONNA WALK....AINT NO WAY AROUND IT BUT TO LEARN TO DRIVE IT....can u minimize it...yes!...but it gonna happen81' HYDROSTREAM VECTOR / slightly Modified 200
05-12-2017, 08:56 PM #265000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I wasn't over trimmed at all, I actually had it tucked under a little and it was still throwing a pretty good rooster tail . It was running pretty flat , almost felt like it needed more bow lift. I tried trimming it up slowly but the only thing that changed was the size of the tail. It almost felt like the ass end was trying to come around instead of chine walking. My old Varmint would chine walk but it could rock the steering wheel a little and get through it most of the time. I don't have the balls to run this one hard for more than a few seconds and I'm really not going very fast
05-12-2017, 09:03 PM #27
Ass end trying to come around...that means too high or over trimmed or both
Remember srx is 14.25" diameter....gonna run lower than 14.5
Make a pass next time out ....post pics or vid81' HYDROSTREAM VECTOR / slightly Modified 200
05-12-2017, 09:21 PM #285000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I've got a video of it from yesterday but I can't get it to upload
05-12-2017, 09:26 PM #295000 RPM
- Jul 2014
- Mississippi
- 196
- 18
Could the relieved exhaust cause any issues besides noise? I've never seen one cut out like this one
05-12-2017, 09:29 PM #305000 RPM
- Jul 2014
- Mississippi
- 196
- 18
There is a rectangle hole cut out just to the to the rear of the lower water pick up hose
need help setting my engine height and jack plate height
By johnsongt175 in forum Props, Setup, and RiggingReplies: 2Last Post: 05-27-2014, 07:21 AM -
HOW to - jack plate height/engine height
By Techno in forum Technical DiscussionReplies: 4Last Post: 08-21-2007, 12:49 PM -
vector engine height,(no lwp)
By vector tim in forum Technical DiscussionReplies: 3Last Post: 09-05-2002, 07:57 PM -
engine height on a vector
By vector tim in forum Technical DiscussionReplies: 12Last Post: 08-16-2002, 07:50 AM
