Results 1 to 4 of 4
Thread: Resin identification? help
05-10-2017, 10:39 AM #15000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Helping a friend with a commercial fishing boat. Have quite a few areas built by previous owner that are delaminating. Most around the cabin wich is roving over foam core. Most of the things glassed into that are delaminating. Is there a way to tell what resin they used, poly, vinyl, or epoxy? So our repairs will not also delaminate. Thanks
05-10-2017, 11:45 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Only safe bet with an un known mix of resins is to use epoxy. Commercial boat is likely poly, imo. You could grind back an area and apply some poly resin and glass and do a pull test. Leave a glass tab sticking up and after cure, grab that with some vice grips and see how hard it is to pull off and see where it breaks. Should tear and come loose leaving some of the new glass behind. If it pulls off cleanly, getting no adhesion, then epoxy is next.
05-10-2017, 06:21 PM #3
Preparation of any surface before glassing is a really really very important issue and yes if it was a commercial build its bound to be polyester ! so from here out doing rebuilding Epoxy is your best safe guard !! But all of the surfaces you are sticking to will need to be ground with a really coarse disc !16 grit if you can find them 24 grit maybe but nothing finer! Making the surface rough and the old glass fibers stand out is the key ! physical bond and well as chemical .Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
05-10-2017, 07:17 PM #45000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
If it was my boat it would be epoxy, but it's gonna get poly. The problem spots I looked at today after peeling everything with a screw driver look like they were not prepped, the base layer was left to dry and they laid up over it without grinding. We got it ground with 24. Hopefully it will stay stuck this time.
How much resin
By dirtjumper101 in forum Fiberglass and Composites DiscussionReplies: 19Last Post: 09-18-2009, 11:43 AM -
How much resin
By Fibertron in forum Fiberglass and Composites DiscussionReplies: 7Last Post: 05-22-2004, 01:08 PM -
Polyester resin over epoxy resin adhesion
By Techno in forum Fiberglass and Composites DiscussionReplies: 6Last Post: 04-01-2004, 08:31 PM -
what resin to use
By Fibertron in forum Fiberglass and Composites DiscussionReplies: 28Last Post: 01-25-2004, 07:47 PM -
which resin
By Pete 88 Venus in forum Technical DiscussionReplies: 22Last Post: 05-18-2002, 08:37 AM
