Results 1 to 6 of 6
    Sep 2008
    mass
    300xs fuel filters
    Should I be running a water separator before the engine or is the one on the motor sufficient? I currently have one in the boat and sometime the motor seems to be starving for fuel and was thinking about removing the in the boat one
    Ft. Lauderdale, Fl
    Been running boat mounted seps on a pair of 225 Opti fish for years without issues. Not sure if Merc recommends using them on the XS's
    Apr 2014
    St. Pete, FL
    I have water separators mounted before the engines with my 250xs'
    Aaron
    Fountain 38TE, quad 400 Verados
    Talon F20 Flats boat, 250XS
    Aug 2012
    Tenkiller Lake, OK
    Have them on my Skater w/ 300XS's. This discussion was up on a thread a while back. I did some research and found that a Raycor 320R flows 60GPH. That is waay more than a 300SX could ever need. Mercury says they are acceptable if installed correctly. Whatever that means!
    With the racors and others i'm sure, you can mount a vac gauge to monitor the restriction the filters are causing.
    May 2001
    Maine
    I have one on my 225 Sport XS
  1. filters for a 300xs
    By bravo 1 in forum Technical Discussion
    Last Post: 07-21-2009, 02:28 PM
  2. Fuel Line Size & Fuel Filters
    By Liberator21 in forum Technical Discussion
    Last Post: 09-26-2004, 08:50 PM
  3. Fuel Filters
    By STV_Keith in forum Technical Discussion
    Last Post: 01-13-2004, 09:38 AM
  4. What Fuel Filters do you run?
    By Sharkey-Images in forum General Boating Discussion
    Last Post: 07-18-2003, 06:10 AM
  5. Fuel filters
    By gtsmpuc in forum Technical Discussion
    Last Post: 06-30-2002, 08:37 PM
