Results 16 to 17 of 17
Thread: Transom repair questions
07-18-2017, 09:44 AM #16Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Looks good. Nice and strong design. One thing though, I am wondering why they didn't cover the wood with glass? Is it painted with epoxy? Not dissing the job at all, just curious.
07-18-2017, 04:26 PM #17
Wood thats 99% encapsulated in glass and any type of resin will never stay dry !! Water will always find a way to get into all those grains in the wood and travel end to end and if the glue line in the ply has gaps moisture will go every where !!,but once in will never get out ,so once wet will stay wet and will rot very quickly !.
Another reason to make ALL under floor areas with big opening at each end so air can flow through naturally , If this was done more often most of the ply wood floors and wooden stringer replacement jobs everyone just loves doing would last much longer ! natural Ventilation its called , also covering the boat and sitting a dehumidifier on the floor inside to dry and suck all and any moisture out from every where !! Yes we been through all this before !
A similar scenario happened with Ferro cement boats! if you paint all the fancy epoxy coatings on the outside you never paint the inside because IN A VERY SHORT TIME IT ALL PEELS OFF because the ferro needs to be able to breath so it can stay dry ! Simple and logical !!Last edited by tunnels; 07-18-2017 at 09:04 PM.
Stv transom repair
By CRAZY FAST JOHN in forum Fiberglass and Composites DiscussionReplies: 31Last Post: 08-06-2013, 05:30 PM -
Transom Need Repair?
By MrPhotographer06 in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 05-17-2008, 09:07 AM -
transom repair on 16'
By riverboater in forum Fiberglass and Composites DiscussionReplies: 1Last Post: 07-18-2005, 08:45 AM -
transom repair 2
By nstaller in forum Fiberglass and Composites DiscussionReplies: 6Last Post: 06-13-2004, 12:38 AM -
transom repair
By yamahadog in forum Fiberglass and Composites DiscussionReplies: 10Last Post: 08-04-2003, 09:25 PM
