Results 1 to 8 of 8
    Sep 2010
    nj
    Ran aground today!
    Got stuck in some mud being polite to avoid some fishing boats, no good deed goes unpunished. Hauled boat, washed and flushed it, had some small particles coming out as the boat was running on a hose. Ran for 15-20 min on hose water was clean with no particles after 2-3 min. Anything else I need to do??
    What engine?
    Sep 2010
    nj
    Merc 250 pro xs
    You have a screen on the port side low on the block that filters the water for the compressor. Follow the water hose from the comp down and remove the nipple fitting from the block. while it is out run the motor on the muffs for 30 secs or so to flush out the crud from the block. Re install cleaned filter and hose. If the engine comes up to temp ok and does not run cold the t-stats are ok. They are prone to getting stuff stuck in them and causing the engine to run cold. Run some weed whacker string into the tell tale from the compressor to clear it good.
    Aug 2004
    Venice, Florida
    Some awesome member did a whole how to post on cleaning that screen
    http://www.screamandfly.com/showthre...water-strainer
    21' Paramount
    Mercury 300 Promax
    He used the word awesome.. How awesome
    Ft. Lauderdale, Fl
    Quote Originally Posted by Mr. Demeanor View Post
    It had pictures and everything, should have been a sticky
    I agree, it was great. He did a lotta work to make it....
  1. 101 MPH Today in the T-3
    By Hot Shot Merc in forum General Boating Discussion
    Last Post: 05-17-2007, 09:52 AM
  2. 238' Alaska State Ferry aground in Sitka
    By AlaskaStreamin in forum General Boating Discussion
    Last Post: 05-18-2004, 05:26 PM
  3. How Bad did you Run Aground????
    By tunnelboat17 in forum General Boating Discussion
    Last Post: 10-02-2003, 07:10 PM
