Results 1 to 7 of 7
    Baton Rouge, La
    Air temperature controlled carb question 1991 14petal 200
    On these carbs are they rich when the valve is closed ? Jet suggestions for an increase in compression from 120 to 147 ? Thanks Mike
    Cheaters never Win !!!
    May 2014
    Livingston, Louisiana
    Rich when valve is closed. Valve opens when engine warms up.
    Baton Rouge, La
    So if I plug the carb fitting we are rich ? You cant catch fish playin on the phone !
    May 2014
    Yep. We done fishing. Shoulda went to Tickfaw lol.
    Baton Rouge, La
    Next time you know!
    May 2014
    Yeah, they said it was pretty rough coming back across Lake Maraupas though.
    Baton Rouge, La
    Been there ! Water shooting over the nose was getting in the cowl vent causing the motor to stall. T Rex broke his seat mounts and we at times couldn't see each other running 15 yards apart. Won't happen again! Mike
  1. Mercury Tech: 2.5 / 280 Air Temperature Sensor wire question?
    By fastkat101 in forum Technical Discussion
    Last Post: 06-30-2016, 06:18 PM
  2. Mercury Tech: 1991 carbed 200 motor temperature?
    By K-Dawg in forum Technical Discussion
    Last Post: 10-05-2012, 03:21 PM
  3. Question on 225 Promax temperature monitoring
    By Bigpower in forum Technical Discussion
    Last Post: 03-20-2012, 10:59 AM
  4. Temperature Question
    By lancer in forum Fiberglass and Composites Discussion
    Last Post: 02-12-2011, 12:41 AM
