Results 76 to 90 of 103
Thread: 1980 Allison rs-16 questions
06-17-2017, 01:32 PM #76Member
- Jun 2010
- over there a minute ago
- 81
- 11
- 90
- 20
Yeah , I live at the 24th latitude N. and know all to well about ridiculous heat . Was working on a project the other day and came inside to re-fill my tea , the weather channel said the heat index was 119 degrees . A friend that helped me for a few hours went home and was sick for the next 3 days . stay safe . capt bart
Last edited by capt bart; 06-17-2017 at 01:34 PM. Reason: lack of anything better to do
06-17-2017, 01:46 PM #77Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Like the higher freeboard, almost ready for downriggers
06-17-2017, 02:50 PM #785000 RPM
- Apr 2013
- South Texas
- 102
Ha! Downriggers! Isn't that a big boat item? lol. I just went and looked at the transom and it looks fantastic. I had seen a video of a guy that had done Arjay and had it pull back from the transom skin creating a small crevasse around the edge. I'm not sure if he had put in fresh glass but back when I did the nidacore transom they advised me to grind if possible and lay up a fresh layer of chop strand mat or at a minimum a fresh coat of resin. I because I built the cavity for this Allison transom I was able to lay up all new glass and I actually used some 1708 and csm to help with strength and bonding. I didn't have any separation and the transom look exactly like it did when I left it last night. It's just a bit tacky to the touch but currently curing out in 30mph wind and 91 degree heat. I will give it a few days to cure out and that will give me a chance to clean my shop up and hopefully Darris responds soon on my spohnson idea so I can make a final decision on spohnson design. I have the outer skins of some spohnsons I laid up over a Rubbermaid storage box my wife was throughing out and they look good and match the wall angle perfectly on the hull lol.
capt bart liked this post
06-17-2017, 02:58 PM #795000 RPM
- Apr 2013
- South Texas
- 102
Its not quite that hot here but down around Falcon Lake in Zapata TX back in my oil field days it would get that hot. We would work with wet rags under our hard hats and you had to keep tools in the shade because leaving them out in the sun you couldn't grab them and work even with gloves on. Working ranch work down here we would work sun up until about 11:00am then go inside and not start work again until 4-5pm and work until dark to avoid the heat of the day.
06-17-2017, 04:09 PM #80Member
- Jun 2010
- 81
- 11
- 90
- 20
Yeah , most people don't understand the reasoning behind the Mexican ''siesta'' . They think that they take a break in the middle of the day because they are lazy . That is not even close . They take a break in the middle of the day because they are smart . It does make for a longer day , but working in the heat of the middle of the day will kill you . The same reasoning applies to why they eat their biggest meal of the day so late in the evening . You have to adjust to your environment if you want to survive .
loop liked this post
06-17-2017, 05:59 PM #81Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
The heat will bring you to stop. Up this way that lifestyle gets you called a stoner. Lol
06-18-2017, 11:29 AM #82
Looks to be a rather left tilted re-build, getting tired of holding the desktop on edge
"have you met my little fly named scream?"
GSE #1 2004 GSE, 2004 225X Promax... RIP
GSE #2 2013, Gen2 200XS ROS
06-18-2017, 04:52 PM #83Member
- Jun 2010
- 81
- 11
- 90
- 20
Chingadera - I just came into the house to see what's up with the wind blowin' like crazy this afternoon and it looks like you might have to bring your dogs inside sometime next week . I'm damn sure not looking forward to another hurricane season .
06-18-2017, 09:51 PM #845000 RPM
- Apr 2013
- South Texas
- 102
My wife mentioned a storm trying to come up this way (I never watch the news because it makes me feel like a bipolar or something) Man I hope wherever it goes people stay safe! Next week weather prediction is lit up with rain chances. They say this year is predicted to be a busy season but half the time they can't predict where the storms are even headed so I don't know what to believe. Stay safe and stay dry man. Thanks for the heads up.
06-29-2017, 07:00 AM #855000 RPM
- Sep 2014
- piedmont S.C./hickory hill TN.
- 187
- 11
making a fishing boat out of this is as bad as putting a chevy motor in a ford.!
H20WKD liked this post
06-29-2017, 09:03 AM #86Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10933
But, it is not as bad as putting a ford motor in a chevy.....
07-08-2017, 09:25 PM #87
That's the only way to get a ford to run good....put a chevy motor in it!!
07-09-2017, 05:07 AM #88
I resemble that remark....
64 yrs & still run'n good, un-restored.
W2F a V-King liked this post
07-09-2017, 05:47 AM #89
07-09-2017, 08:10 AM #90
DW's Grandmothers first new car, registered every year since 1953....
We've been the custodians since 1976.
BobLast edited by H20WKD; 07-09-2017 at 08:15 AM.
1980 Merc Questions
By kchighrider in forum Technical DiscussionReplies: 11Last Post: 06-03-2014, 05:29 PM -
IllinoisRiverRat 1980 Champion Swift/1980...Prop setup
By IllinoisRiverRat in forum Props, Setup, and RiggingReplies: 22Last Post: 07-31-2013, 09:57 PM -
Mercury Tech: 1980 Inline 6 115hp questions
By greycat in forum Technical DiscussionReplies: 19Last Post: 08-20-2008, 09:56 AM -
Allison Questions....
By Michael Martin in forum General Boating DiscussionReplies: 7Last Post: 10-07-2002, 05:48 PM
