Results 1 to 7 of 7
04-28-2017, 08:35 AM #1New Member
- Apr 2017
- Houston
1980 Tower of Power Troubleshooting
Hi all,
I finally have a weekend free to do some troubleshooting on my 1980 inline 6 Merc 115 and I'm hoping to get some opinions.
A couple of weeks ago I started the day on a battery fresh off the charger. The motor started but I could tell the battery wasn't strong - I figured running the engine would keep it charged enough to make it through the day. Started and stopped a few places, then made a ~15 mile run near top speed. About halfway back, the motor died at full speed. The battery was too dead to get it restarted. When I got home, I put in a known good battery and it started right up and idled fine. Unfortunately I didn't have tools available to troubleshoot.
My question is this: Does that sound like a stator issue or rectifier...or both? Do you have any troubleshooting tips or links to specific procedures? I'm planning on firing it up on the good battery, checking running voltage and pulling the battery to see if the motor can run while disconnected. Any other advice?
Thanks in advance.
04-28-2017, 09:21 AM #25000 RPM
- Apr 2002
- wisconsin
- 843
- 20
Id think twice about disconnecting the battery while running, I dont think its good for the electronics.
garybvd
04-28-2017, 09:35 AM #3
Could be stator or rectifier issue, shop manual, ohm meter, and DVA will be needed to narrow it down. Battery connections clean and more than finger tight?
04-28-2017, 09:45 AM #4Member
- Sep 2013
- Knoxville, TN
- 68
- 16
- 24
04-28-2017, 10:47 AM #5
I would have to agree with the above post.
RockTeam Junk
04-28-2017, 04:36 PM #6
Disconnecting the battery while running,will instantly blow the rectifier! If the battery is in fact good,Put a test meter set on 20volts across battery while running above 2000 RPMs Should read more than 13volts.Think the rectifier is most likely dead.
Glasstream15 thanked for this postGlasstream15 liked this post
05-24-2017, 12:31 PM #7Member
- Dec 2010
- Denmark
- 98
- 9
If it is an old carburated ingine.
Then when the engine is started, it is able to run without any power on the Battery. Then the Battery is only used to start the engine.
So it could be your stator that is burned.
Note: that a lot of other components can have faults also.
regards Thomas
Mercury 115 Tower of Power power trim
By baja030 in forum Outboard EnginesReplies: 14Last Post: 11-11-2017, 11:16 AM -
115 tower of no power
By Keebibear in forum Technical DiscussionReplies: 4Last Post: 06-05-2011, 08:50 PM -
tower of power in the 80's
By mk55 in forum Outboard and Racing HistoryReplies: 3Last Post: 08-18-2008, 06:20 AM -
tower of power Q
By dorc in forum Technical DiscussionReplies: 21Last Post: 07-13-2004, 10:25 PM
