Results 31 to 45 of 65
05-01-2017, 11:57 AM #31
Interesting read on epoxy, albeit biased by a site that uses the "West System"epoxy.
Both links are short reads.
http://www.epoxycraft.com/10-myths-epoxy-cured-part-1/
http://www.epoxycraft.com/10-myths-epoxy-cured-part-2/James H. W2F a V-King... Want 2 Fly a V-King
XstreamVking liked this post
05-01-2017, 12:20 PM #32Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Everybody that knows glass work, knows that epoxy is far superior to any poly. West is only beating their own drum...Vinyl has closed the gap but it is not the equal of a quality, hi solids epoxy. Epoxy is still the most expensive resin out there. That is the only drawback to it....
05-01-2017, 04:58 PM #337000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
Ignorance is another drawback to getting folks to use epoxy.
05-01-2017, 05:19 PM #34
Ignorance and coupled with a little stupidity and there you have it folks !!
Its really not worth it ! If it was necessary then why wasn't the boat made with epoxy in the FIRST PLACE ? Basic simple WORKMANSHIP is where the biggest and most important issues lay .
OH BUT I USED EXSTENSIVLY THE BEST EPOXY RESIN AVAILIBLE SO IT MUST BE GOOD !! BUT if the workmanship is not what it should be like is seen so many times then in reality its a total waste of time !Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
05-01-2017, 05:22 PM #35Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
05-01-2017, 05:43 PM #367000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
THIS POLYESTER THING IS LIKE LISTENING TO AN OLD BROKEN RECORD ! over and over and over and over again !
05-01-2017, 05:47 PM #37
ohh polyester and vinylester don't forget !! over and over and over and over again !
If it wasn't for either of these esters you wouldn't have little boats to tinker with , you'd be still looking for hollow logs along the shore line to race !
ok if you going over WOOD then yes epoxy is best to use ! so you can use it to skin your hollow wooden log !Last edited by tunnels; 05-01-2017 at 06:41 PM.
05-01-2017, 07:26 PM #387000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
Epoxy gets used a lot in aircraft from some reason. Do you know why? That's where I started using it 30 years ago.
05-01-2017, 08:19 PM #39Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
and boat masts, they skipped esters knowing too heavy and not strong enough versus aluminium.
and foils on foiling boats, even then many or the angled corners are milled from titanium and inserted into the 2 carbon epoxy sections
and Formula 1 car chassis, another technology that went from ally to carbon
and squash rackets
and competition water skis - tech straight from boeing
and
05-01-2017, 08:34 PM #40James H. W2F a V-King... Want 2 Fly a V-King
05-01-2017, 11:23 PM #41Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
05-01-2017, 11:27 PM #42Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
05-02-2017, 12:06 AM #43Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
05-02-2017, 03:08 AM #44
you have underestimated whats all ready been done
There are much better light weight resins now than either of those 3 and once the price becomes more competitive you'll be seeing them getting use ! But in all my years of making hundreds of different things have never ever had to think about using epoxies apart from glues and skinning wooden boats that all !Last edited by tunnels; 05-02-2017 at 03:16 AM.
05-02-2017, 03:24 AM #45Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Wraping hi density foam into tight places without using heat and makingthe foam hard
By tunnels in forum Fiberglass and Composites DiscussionReplies: 11Last Post: 01-22-2017, 05:54 PM -
Glass wrapped foam sheet
By Carter Powell in forum Fiberglass and Composites DiscussionReplies: 9Last Post: 08-15-2014, 05:48 PM -
Foam sheet or pourable foam?
By bigboy in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 11-03-2010, 02:01 AM -
Homologation sheet
By thephantommence in forum Technical DiscussionReplies: 6Last Post: 11-10-2009, 04:00 PM -
OMC spec sheet
By David_L6 in forum Outboard and Racing HistoryReplies: 5Last Post: 01-11-2003, 06:48 AM
