Results 1 to 3 of 3
    Apr 2017
    Holland,MI
    Promax blowing trim fuse
    I'm at a loss with this. Just finished putting a promax 225 on my already rigged boat and it keeps blowing the trim pump fuse cutting all power to the motor. I've already inspected all the wires in the boat and none of them are shorting or arching. Is it a solenoid? Or something else?
    Apr 2017
    Holland,MI
    It happens just when it is idling or higher rpm's. I could push the trim up and down all day and it won't blow, only after running for a minute or so, just instantly cuts power, can't even turn it over. Replace the fuse and everything works again.
    20 amp fuse should be connected to batt side of the starter solenoid. if it only blows when running must have a short on the purple circuit some where in the harness.
  1. Mercury Tech: 225X fuse blowing???
    By tozlakes in forum Technical Discussion
    Last Post: 06-11-2014, 09:33 AM
  2. Blowing trim pump fuse
    By 2fast4mom in forum Technical Discussion
    Last Post: 04-06-2013, 03:56 PM
  3. Keep blowing 20amp fuse...why?
    By Raddude! in forum Technical Discussion
    Last Post: 06-20-2009, 10:28 PM
  4. 2.4 blowing 20 amp fuse
    By Toostrokin in forum Technical Discussion
    Last Post: 05-05-2006, 05:47 AM
  5. 2.5 blowing fuse
    By blackcloud in forum Technical Discussion
    Last Post: 09-21-2005, 08:28 AM
