Results 1 to 15 of 16
    Apr 2017
    Holland,MI
    Bypassing neutral safety switch
    I need help bypassing the switch so I can start in gear. I haven't been able to find anything on it, boat is an 88' with quicksilver control box.
    May 2014
    Livingston, Louisiana
    There should be two yellow/red (If I remember colors correctly, 95 % sure that was the colors lol)wires coming out of back of control box. You will need to connect these two wires together.
    Apr 2017
    Holland,MI
    Great, thanks
    Apr 2017
    Holland,MI
    I tried every possible combination and none worked. Any other ideas? Or am I out of luck with this one
    May 2014
    You hooked them together in the boat harness side?
    Apr 2017
    Holland,MI
    Yes, hooked them together, left them apart, swapped colors, none of it worked.
    May 2014
    I'm sorry it should be two yellow with red stripe wires going to box. Connect these two together on boat side to bypass neutral safety switch. Not good at remembering my colors, I'm getting senile!
    Apr 2017
    Holland,MI
    No problem! I will try these once i get the motor back together, thanks.
    Sep 2009
    Lake One
    With turn signal trim switch....
    I wired both GS#1 & #2 using the shifter trim switch's to start in gear, the advantage is, it still needs to be in neutral to start with the key.
    Leave the trim power wire at the shifter intact, cut & connect the trim up and down wires together and splice them into the neutral safety wire to the starter solenoid.
    "have you met my little fly named scream?"
    GSE #1 2004 GSE, 2004 225X Promax... RIP
    GSE #2 2013, Gen2 200XS ROS
    Mar 2015
    DFW
    Do what...
    Quote Originally Posted by h20wkd View Post
    with turn signal trim switch....
    I wired both gs#1 & #2 using the shifter trim switch's to start in gear, the advantage is, it still needs to be in neutral to start with the key.
    Sep 2009
    Lake One
    If your boat is equipped with a turn signal trim switch, the shifter trim switch,(Merc), is redundant.
    Shifter trim wires..red power. Blue/wht, Grn/wht up & down.
    Cut the up & down wires from the switch, splice together and then splice those into the power wire from the neutral safety switch to the starter solenoid.
    You still need to be in neutral to start with the key, but the shifter trim button can be used to start in gear with the key on.
    Bob
  12. Likes XstreamVking liked this post
  13. #12
    Mar 2015
    DFW
    ok now I get it! Sometimes my eyes and my thinker don't communicate all that well at night!
  14. #13
    Apr 2017
    Holland,MI
    This is what I did. I connected the yellow and burgundy wire with the yellow and red wire and it worked.
  15. #14
    Mar 2015
    DFW
    Thats how I have always seen it done previously. Bob's method is pretty cool though, turns it in to a button start as long as the key is on, I kind of like that. I'll be running a Rex shifter with no switch on the boat I'm rebuilding so hopefully none of this even matters for my application. Great information fellas!
    Quote Originally Posted by ShadowFlier View Post
  16. #15
    Mar 2010
    houston, tx
    You can add a momentary button also and wire the button from 12v source to the trigger onnthe start solinoid.
    Turn key on and push button. It will still roll over without the key on but won't start and you don't have to dig into the control box this way.
    All mine are done this way
  17. Likes W2F a V-King liked this post
  1. Neutral safety switch
    By tony brimeyer in forum Technical Discussion
    Last Post: 03-26-2015, 01:13 PM
  2. Neutral Safety Switch
    By delgrad59 in forum Technical Discussion
    Last Post: 12-22-2010, 04:54 PM
  3. Neutral safety switch or not?
    By Gorilla0178 in forum Technical Discussion
    Last Post: 12-14-2010, 02:04 AM
  4. Mercury Tech: Neutral safety switch
    By fireedge11 in forum Technical Discussion
    Last Post: 04-13-2010, 06:17 AM
  5. Bypassing neutral safety switch Merc 175 stk controls
    By WSJR1 in forum Technical Discussion
    Last Post: 05-03-2006, 11:39 PM
