Results 16 to 18 of 18
05-15-2017, 04:58 PM #165000 RPM
- Jun 2014
- South Carolina
- 161
- 28
- 13
- 59
- 54
Figured I'd update this as I go FWIW
Trim didn't fully bleed on the stand with crane, had to get motor on the boat and cycle/bleed and that fully cured the droop.
Greased zerk fittings, inspected plugs, replaced impeller assembly, fuel tank drained, fuel pump housing drained, fuel/ water separator replaced, filled with fresh 89 octane and Quickclean.
05-15-2017, 05:05 PM #175000 RPM
- Jun 2014
- South Carolina
- 161
- 28
- 13
- 59
- 54
Had no spark on all 6.. went thru ignition wiring, I wired the kill switch on the I terminals, switched to M terminals and it fired up on 2nd key turn.
Strong, smooth idle, little smoke, 160 degrees, 5psi water
Took to the lake immediately
Boat won't get on plane.. same prob as 93Hydrasport
throttle pinned, motor doesnt respond.
Going to go thru fuel system, gut feel is fuel delivery..
06-07-2017, 08:36 PM #18Junior Member
- Jun 2017
- N.W. Wisconsin
- 7
Would you have a pdf file for a 1998 225 Opti?
Thanks
1998 merc. 2.5 175
By mirage101 in forum Parts WantedReplies: 4Last Post: 07-17-2015, 12:46 AM -
1998 johnson 225 cowling for rigging
By bsullivan403 in forum Technical DiscussionReplies: 0Last Post: 08-22-2010, 10:01 AM -
Noob: Motor Tune VS Prop question 2.0 merc
By grendle in forum Technical DiscussionReplies: 4Last Post: 02-06-2010, 11:37 PM -
Basic Question: What's the difference between L6 and V6 Merc LU's?
By ShorePounder in forum Technical DiscussionReplies: 10Last Post: 03-01-2002, 06:18 PM
