Results 1 to 5 of 5
Thread: 175 XRI fuel injection
04-18-2017, 12:43 PM #1Member
- Mar 2004
- Archer,Florida
- 49
I have a xri 175 fuel injected engine that I am replacing the hp fuel pump on. when I removed the inlet hose, the rubber check valve thats supposed to be in the fitting on the bottom of the VST was inside the inlet hose. Merc part# 18241. It's ripoff expensive at around $340. Question is since the fuel pump also has check valves, has anyone tried running without this little piece of solid gold? I know in later engines there is no such valve and they make pressure just fine.
04-18-2017, 12:50 PM #2
That's just criminal... I would find a way to run without out, like you say. A little cheaper here if your back's against the wall and you can't run without it: http://mercuryperformance.com/18241-...-p-138312.html
iwannagofast thanked for this post
04-18-2017, 12:54 PM #3Member
- Mar 2004
- Archer,Florida
- 49
Yeah, I know I can get it cheaper, but I was wondering if anyone had any experience on not using it. I'm almost done putting it back together without, so Ill have an answer soon.
04-18-2017, 01:50 PM #4Member
- Mar 2004
- Archer,Florida
- 49
David - WI liked this post
04-21-2017, 10:04 AM #5
point in time of fuel injection, has anyone played w/ different injection points?
By mrcrsr in forum Technical DiscussionReplies: 7Last Post: 01-28-2011, 08:21 AM
