Results 1 to 12 of 12
    Jun 2014
    Farmington Hills Mi
    HELP! need bow lift Champion 21 SX
    Help anyone?
    I need help with bow lift.
    I love the boat but need help with bow lift
    2003 Champion 21SX
    225 opti.
    10" slide master
    25 tempest stock
    5600RPM @60 MPH gps.
    4.5" below thee pad
    Yep rods and tackle.
    All but the rods are in the back
    Need more bow lift boat is not on the pad and to wet.
    I have tried 23 Tempest 24 trophy and have had the motor 3" to 4.5" below the pad.
    Any help would be appreciated.
    Thanx
    May 2017
    US / NC
    I would say try a bravo or Rev -4 prop if you could get your hands on one ?
    Feb 2017
    Wixom lake michigan
    Send your tempest out to mark croxton for a balance/blueprint, tell him what your after, he will get some bow lift outta it
    May 2017
    US / NC
    Quote Originally Posted by JasonRS View Post
    +1 also Mark is good ...i send all my props to him to repair or to just true them up . He also can fix it with out balance and blueprint it . Ask him what he would do to it .
    Quote Originally Posted by RiChavis View Post
    Hey guys could someone post his contact info? Thanks Gary
    Feb 2017
    Wixom lake michigan
    Marks Props*317-398-9294, 1850 East 225 South, Shelbyville, Indiana 46176*propellerman59@gmail.com
  7. Thanks olboatman thanked for this post
    Feb 2017
    Wixom lake michigan
    I had him work a 27p T1 for my 202 champion, bow lift is nothing short of incredible
  9. #8
    Jul 2017
    Elk grove
    I have a champion as well I run. 25 tempest prop I had to lift motor to 2.75 inch to pad now I can barley keep the boat in the water. I had to adjust in 1/8" increments tell I found that sweet spot.
  10. #9
    Mar 2015
    Southeast Texas
    Had a champ 20' back in the day (25 years ago) with a pro-v 150 on it...way underpowered. Had lots of trouble finding a prop for that combination. Tried a buddy's High Five (old merc 5 blade) and it was a different boat...shot out of the hole, turned like Ferrari and carried the bow. Sacrificed a few mph on the big end but I wasn't going to be breaking any speed records anyways so it was a fair tradeoff to me. They are cheap too...I still have a it. I run it on my current boat when I fish shallow marsh cuz I don't care if I trash it (mud)...but it has thick blades on it and is still in excellent shape. Current boat comes out of the hole completely out of the water, lands and then takes off like a top fueler. Can't trim it much at all cuz of all the bow lift. Fun prop to goof off with...
    96 Bullet 20cc, Yamaha OX 250+, 10" jack, labbed 30" Bravo LH w/1.25" exhaust pipes, counter rotating Bob's lower...it goes faster when you spin it the other way...
    02 Dodge Cummins 2500 reg cab 4x4, converted long to short bed, up a foot, twins, injectors, fully built auto, dyno'd 582hp/1015tq
    99 Dodge Viper GTS Coupe, 8.0L V-10, lowered 1", Corsa pipes/no cats, 450hp/500tq
  11. #10
    Ontario, Canada
    Quote Originally Posted by jonl21sx View Post
    Help anyone?
    4.5" below thee pad. I have tried 23 Tempest 24 trophy and have had the motor 3" to 4.5" below the pad.
    jon...Just wondering what your results were when you tried the motor at higher positions? (When you reference 3" to 4.5" below the pad - are you referring to the centerline of the lower unit "bullet" to being 3" to 4.5" below the pad?) You would certainly gain speed and help move onto the pad with motor raised higher!
  12. #11
    Oct 2005
    savannah,ga
    Had a mean 17 way back in the early 80s. It loved a big chopper. Also the High 5 was a good fishing prop on my Paramount.
  13. #12
    Jul 2017
    Elk grove
    It runs the best at 3" to 2 7/8 7 mph on top end I did have to mess with the plugs a little in the pro. I took a day and just dedicated it to set up you be amazed what easing that motor does. With the correct prop
  1. Hydrostream Valero, Which Prop? need more bow lift less stern lift,
    By Dregsz in forum Props, Setup, and Rigging
    Last Post: 05-03-2018, 08:47 PM
  2. Bow lift or stern lift for Charger STV Mod Vee?
    By Mhoward in forum Props, Setup, and Rigging
    Last Post: 03-29-2014, 04:11 PM
  3. Boat Lift, Great Lakes Lift
    By Flatlander in forum General Boating Discussion
    Last Post: 02-15-2013, 01:35 PM
  4. how do you know if you need bow lift or stern lift?
    By Looper8Man in forum Technical Discussion
    Last Post: 10-07-2004, 06:11 AM
