Results 1 to 12 of 12
04-16-2017, 09:48 AM #1Junior Member
- Jun 2014
- Farmington Hills Mi
HELP! need bow lift Champion 21 SX
Help anyone?
I need help with bow lift.
I love the boat but need help with bow lift
2003 Champion 21SX
225 opti.
10" slide master
25 tempest stock
5600RPM @60 MPH gps.
4.5" below thee pad
Yep rods and tackle.
All but the rods are in the back
Need more bow lift boat is not on the pad and to wet.
I have tried 23 Tempest 24 trophy and have had the motor 3" to 4.5" below the pad.
Any help would be appreciated.
Thanx
06-01-2017, 02:17 AM #25000 RPM
- May 2017
- US / NC
- 131
I would say try a bravo or Rev -4 prop if you could get your hands on one ?
06-01-2017, 01:43 PM #35000 RPM
- Feb 2017
- Wixom lake michigan
- 177
- 40
- 9
- 293
- 34
Send your tempest out to mark croxton for a balance/blueprint, tell him what your after, he will get some bow lift outta it
06-01-2017, 11:09 PM #45000 RPM
- May 2017
- US / NC
- 131
06-02-2017, 06:29 AM #5"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
06-02-2017, 07:30 AM #65000 RPM
- Feb 2017
- 177
- 40
- 9
- 293
- 34
Marks Props*317-398-9294, 1850 East 225 South, Shelbyville, Indiana 46176*propellerman59@gmail.com
olboatman thanked for this post
06-02-2017, 07:32 AM #75000 RPM
- Feb 2017
- 177
- 40
- 9
- 293
- 34
I had him work a 27p T1 for my 202 champion, bow lift is nothing short of incredible
09-02-2017, 03:30 AM #8Member
- Jul 2017
- Elk grove
- 31
I have a champion as well I run. 25 tempest prop I had to lift motor to 2.75 inch to pad now I can barley keep the boat in the water. I had to adjust in 1/8" increments tell I found that sweet spot.
10-13-2017, 04:02 AM #9
Had a champ 20' back in the day (25 years ago) with a pro-v 150 on it...way underpowered. Had lots of trouble finding a prop for that combination. Tried a buddy's High Five (old merc 5 blade) and it was a different boat...shot out of the hole, turned like Ferrari and carried the bow. Sacrificed a few mph on the big end but I wasn't going to be breaking any speed records anyways so it was a fair tradeoff to me. They are cheap too...I still have a it. I run it on my current boat when I fish shallow marsh cuz I don't care if I trash it (mud)...but it has thick blades on it and is still in excellent shape. Current boat comes out of the hole completely out of the water, lands and then takes off like a top fueler. Can't trim it much at all cuz of all the bow lift. Fun prop to goof off with...
96 Bullet 20cc, Yamaha OX 250+, 10" jack, labbed 30" Bravo LH w/1.25" exhaust pipes, counter rotating Bob's lower...it goes faster when you spin it the other way...
02 Dodge Cummins 2500 reg cab 4x4, converted long to short bed, up a foot, twins, injectors, fully built auto, dyno'd 582hp/1015tq
99 Dodge Viper GTS Coupe, 8.0L V-10, lowered 1", Corsa pipes/no cats, 450hp/500tq
10-13-2017, 09:18 AM #10
jon...Just wondering what your results were when you tried the motor at higher positions? (When you reference 3" to 4.5" below the pad - are you referring to the centerline of the lower unit "bullet" to being 3" to 4.5" below the pad?) You would certainly gain speed and help move onto the pad with motor raised higher!
10-13-2017, 06:30 PM #11
Had a mean 17 way back in the early 80s. It loved a big chopper. Also the High 5 was a good fishing prop on my Paramount.
10-13-2017, 08:43 PM #12Member
- Jul 2017
- Elk grove
- 31
It runs the best at 3" to 2 7/8 7 mph on top end I did have to mess with the plugs a little in the pro. I took a day and just dedicated it to set up you be amazed what easing that motor does. With the correct prop
Hydrostream Valero, Which Prop? need more bow lift less stern lift,
By Dregsz in forum Props, Setup, and RiggingReplies: 18Last Post: 05-03-2018, 08:47 PM -
Bow lift or stern lift for Charger STV Mod Vee?
By Mhoward in forum Props, Setup, and RiggingReplies: 8Last Post: 03-29-2014, 04:11 PM -
Boat Lift, Great Lakes Lift
By Flatlander in forum General Boating DiscussionReplies: 0Last Post: 02-15-2013, 01:35 PM -
how do you know if you need bow lift or stern lift?
By Looper8Man in forum Technical DiscussionReplies: 4Last Post: 10-07-2004, 06:11 AM
