Results 16 to 30 of 34
04-19-2017, 08:23 AM #16Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
For what it's worth I've used Royal Purple for years, holds its properties and protects. They changed weight slightly with a new product this year but 75/ 90 works for me.
04-19-2017, 09:28 PM #17Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
Truth is most any lube will work, long as is clean and free of water.. the differences in performance between a quality lube and what is the most awesomest super goo will be very minimal.. many manual trans use atf and it will work in a gearcase too, again provided its clean and changed reasonably often.. outboard short blocks survive on a mist of barely lubed fuel, a gearset operates in a bath of oil, difficult to cause wear under those conditions.. you may break something that's caused by impact, slung blade, broke shaft etc but it won't be the oil's wrong doing..
Kevin Kiser
04-19-2017, 09:54 PM #18
As long as it can handle the heat of packing a 2200 plus lb boat with the whole bullet above water not being able to get cooled and turning a 27 pitch prop above 80 mph for 20 plus miles without breaking down and loosing its lubricating abilities it'll be just fine. These lowers get extremely hot and just any old oil ain't gonna cut it.
04-20-2017, 05:56 AM #19
Thats how I look at it.....you can compare it to NASCAR that pushes their rear gear sets to the max for 500 mi or so. They use oil coolers to keep the temps down where my truck can run the interstate at 75 for hrs with no problems. When runnin the LU that high for that long has anyone used a "shower" to keep the temp down as they have on I/O LUs ? Just wondering. Gary
04-20-2017, 06:13 AM #20Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
Water exits through the bullet and helps
Kevin Kiser
04-20-2017, 06:21 AM #21
Think about the amount of pressure we are putting on a tiny set of high ratio gears with less than a quart of oil compared to 8-13 inch ring gears with much lower ratio and multiple quarts of oil turning much less rpms. We expect a lot out these things and it's no different with oil. It has to be some good stuff! For short spurts any old lubricant and any old viscosity will go just fine, but for the long haul you better know you got the right stuff with the right additives that can handle the job in there.
04-20-2017, 06:24 AM #22
04-20-2017, 06:53 AM #23"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
04-20-2017, 07:38 AM #24
I have run it in my raceboats for years. The proplem with the synthetic is like was stated before is water intrusion. The water will mix with dino oil and still provide some lubricating properties were as synthetic will not.
04-20-2017, 10:26 AM #25
04-20-2017, 12:04 PM #26Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
I'll try to remember if I've ever hurt a set of gears and post back
Kevin Kiser
04-20-2017, 12:43 PM #27
I run the Alisyn 0w in all my lowers. Good stuff. Seems to last just as long as the Merc hi per oil. I lost a seal once it mixed with the water and made like a grease. Every thing was good. Was a mess to wash out lower. I have pics somewhere. Maybe I was lucky.
2012-2013 DSRA PRO STOCK HIGH POINTS.
2013 DSRA SUPER STOCK HIGH POINTS.
2014 DSRA SUPER COMP HIGH PONTS.
2015 DSRA SUPER COMP HIGH POINTS.
2014,15,16 ODBA SUPER STOCK WORLD CHAMP.
2016 ODBA SUPER STOCK HIGH PIONTS.
2017 ODBA Modified World Champ
04-20-2017, 12:43 PM #28Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
cranking one in gear to prevent shavings, a straight prop shaft and a well balanced prop goes a long way too but that's getting outside the orig question
Kevin Kiser
specboatops liked this post
04-20-2017, 01:46 PM #29
Like I stated before I'm not saying allisyn is responsible for bearing and gear wear. Propshaft breaking at thrush washer was just fatigue of an old shaft. I was a firm believer in the allisyn and even convinced a few people to switch over to it. I ran it for a few years with no noticeable problems. When I drained fluid to tear down lower to replace propshaft and reseal, fluid was clean. It concerned me when I found the wear on pinion and reverse gear. Appeared to be damage from overheating. I switched back to Mercury oil in case(never had any internal failures with it). Gonna run it and see how much life I get out of lower. If I loose another gear or bearing going back to allisyn and take it that it's just part of the price you pay to play. If no failures then this rig is staying on Mercury oil. Just wanted to share my experience. And as far as any lubricant will work just isn't true. These are the best two oils I've used, just think allisyn better for race applications and Mercury best all around. I'll let ya now in few years (hopefully) how the Mercury oil held up. This is also a non hypo coned lower that I'm putting through the ringer and may be just the way it is with either oil, were soon to find out.
04-20-2017, 03:58 PM #30Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
maybe another ingredient is what kind of use will the gearcase see.. will it be cruising mostly with short to moderate burst, or the throttle crammed against the stop for miles and miles on end.. ..
not to create confusion, when I mention any oil my thoughts are in regard to known quality oils.. merc, evinrude, Yamaha, pennzoil, Mobil, klotz, redline etc.. known quality oils, in a healthy case, shimmed correctly, fluid fill changed reasonably oftenLast edited by Ted Stryker; 04-20-2017 at 04:06 PM.
Kevin Kiser
FORBESAUTO, Magcat 62 liked this post
Retired Drag boat ready for some river running.
By dagodiver in forum General Boating DiscussionReplies: 10Last Post: 01-14-2014, 01:51 PM -
Hudson River Running
By Marko in forum General Boating DiscussionReplies: 5Last Post: 04-27-2009, 07:41 PM -
? What Is The Weight Of Midsection And Gearcase
By skiboater in forum Technical DiscussionReplies: 0Last Post: 08-09-2005, 04:26 PM -
What do ya'll consider a good weight for a lake boat?
By KaptainKirk in forum General Boating DiscussionReplies: 11Last Post: 06-30-2003, 10:53 PM
