Results 1 to 15 of 41
Thread: Which prop ?
04-12-2017, 09:28 PM #15000 RPM
- Jul 2014
- Mississippi
- 196
- 18
Which prop ?
Any recommendations and which prop to try first on my Hydrostream Vector with 2.5 EFI 150 ?
04-13-2017, 08:05 PM #2Team Member
- Lake Coochiching, Ontario
- 7,758
- 272
- 485
- 1577
- 6 Post(s)
How high is the engine? All round use or top end? 2:1 gearcase? 30 small ear chopper if you can find one is my low buck choice. 30 ET if you have money.
04-13-2017, 09:25 PM #35000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I'd like it to be able to come out of the hole easy with a couple people in it. I just put the jack plate and motor on it today , I set the jackplate in the center of its adjustment slots and have the prop shaft about even with the pad . I'm going to try to finish rigging it this weekend so hopefully I'll be able to run it soon. I have it setup side steering with Seastar Pro steering , 3" Slidemaster plate . The only prop I have is a 4 blade Trophy 25p, I figured I would go ahead and try to find a better one
04-16-2017, 08:15 AM #45000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I found this one, would this one be a good prop to start out with? http://m.ebay.com/itm/252845012696
04-17-2017, 07:33 PM #5Team Member
- 7,758
- 272
- 485
- 1577
- 6 Post(s)
Yes to the EBay prop. Your Trophy should have good acceleration and run mid 60's
04-17-2017, 07:37 PM #65000 RPM
- Jul 2014
- Mississippi
- 196
- 18
Does the price seem ok even though it needs a hub replaced?
04-18-2017, 07:20 PM #7Team Member
- 7,758
- 272
- 485
- 1577
- 6 Post(s)
It has a bite out of a blade plus hub trouble? I'd try my luck on some of the props for sale here than buy known issues. If it were my money...
04-18-2017, 08:17 PM #85000 RPM
- Jul 2014
- Mississippi
- 196
- 18
Thanks for the advice. I've been looking but I'm not sure what to buy. The boat is almost ready to take for a test run. It's been a ton of work so far, hopefully it runs as good as it looks.
04-18-2017, 08:29 PM #95000 RPM
- Jul 2014
- Mississippi
- 196
- 18
Are all the Mercury props the same spline and size hub?
04-19-2017, 05:35 AM #10Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
All v-6 props are the same except for the "fat shaft" series used on the racing lower units. I would run the prop u have before I bought any more. Need a starting point to move fwd. Get some vids of it running and see how it runs out.
whipper liked this post
04-19-2017, 06:39 AM #11
There's a 27 srx in the marketplace that needs a polish that dropped price to $250. I like mine, and others seem to like it too.
Josh Peterson
04-19-2017, 06:49 AM #125000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I know that's what I should do but I'm getting excited about it as it comes together and ready to put a nasty looking prop on it !!
04-19-2017, 06:54 AM #13Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
One prop will not do it all. I have 3 I run on my V-King. Depending on what I will be doing that day. ET for top speed. chopper for playing around with med load, and a tempest thru hub for a heavy load or for running in the rougher salt water areas. The trophy might work for a playing around prop. A real go fast prop will cost more and not be intended for everyday use.
Dave Strong liked this post
04-25-2017, 11:38 AM #145000 RPM
- Jul 2014
- Mississippi
- 196
- 18
How about a 27 SRX ? I found a nice one for sale not too far from me
04-25-2017, 12:09 PM #15
They are fast props, I would try it if the price is right. One of the fastest props for the money. If you don't like it I may buy it from you
OMC Tech: Help! 225 carbed Johnson melting prop hubs / high exaust temps through prop hub
By Tunnelvision1995 in forum Technical DiscussionReplies: 7Last Post: 09-12-2017, 08:03 PM -
Prop slip on overhub prop related to no exhaust relief?
By B.Mac in forum Technical DiscussionReplies: 7Last Post: 10-06-2015, 03:25 PM -
Performance Prop ,ET, Yamaha or Hydromotive 4 Blade Prop ???
By DonChicho in forum Technical DiscussionReplies: 6Last Post: 12-20-2002, 10:49 AM
