Results 1 to 5 of 5
Thread: Hydrostream drain plug type
04-11-2017, 08:38 PM #15000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I'm finishing up my Vector and was getting ready to install the drain plug tube and I got to thinking if I should use a drain tube and a expansion type plug or a use a garboard type plug? What are y'all using on your Hydrostreams?
04-12-2017, 05:58 AM #2
The way I have looked at it is if the boat is going to stay in the water for any length of time I like the garboard type. If she's a trailer queen then the expansion type is a lot easyer to remove (no tools). JMO Gary
04-12-2017, 06:19 AM #3Screaming And Flying!
- 14,753
- 381
- 1305
- 5603
- 11035
Is it cored at the drain plug area with a wood block? If yes, then use a peened tube sealed with 5200 caulk. If solid glass then you could use a normal snap or twist type plug. (That's the set up I have). Or u could use the garboard type if you want.
04-12-2017, 07:16 AM #45000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I was just worried about the expansion type plug coming out at high speed . It is a standard wood and glass setup, I think the garboard type may lead to water intrusion in the wood. Now that I think about it, my Varmint never had any problems with a rubber plug. Thanks
04-12-2017, 08:41 AM #5
Uh Oh.. Is this bad?! Metal on the drain plug.
By waterboy222 in forum Technical DiscussionReplies: 20Last Post: 01-30-2012, 06:35 AM -
T-Plug Drain to be replaced with garboard plug
By century29 in forum Technical DiscussionReplies: 5Last Post: 10-15-2009, 07:31 PM -
Stv plug drain ?
By H. Hogan in forum General Boating DiscussionReplies: 6Last Post: 07-28-2008, 08:10 PM -
Drain plug hole?
By UrbanLegend49 in forum General Boating DiscussionReplies: 5Last Post: 07-17-2008, 08:46 PM -
Drain plug solution.
By Techno in forum General Boating DiscussionReplies: 2Last Post: 10-29-2001, 04:18 PM
