Results 1 to 15 of 28
Thread: Rub rail for a hydrostream vking
04-09-2017, 07:34 AM #1
Any suggestions where to get rub rail for a vking? Is is the j style. Thanks
04-09-2017, 08:08 AM #2Member
- Sep 2016
- BFE
- 54
- 17
- 15
I've been doing some research myself for my Valero. Some folks recommend HydroStream out of Canada. If you search google for "flange-style" rub rail, several results come up. Some screw into place then are covered by a vinyl piece and some snap on. TACO marine makes one I'm considering. There's also a guy over on hydrostream.org that had a quantity of some that appeared very close to stock, but his posts are several years old. Do a search over there- he posted his contact info. Good luck.
04-09-2017, 01:12 PM #3
You won't find any.The dies were owned at one time by John Spathe I believe,he told me they were stored at the extrusion plant that he bought the rail from.There was a long stretch when he did not order any rail, and the plant threw the dies away.He now uses a vinal snap on style like this.I used it on mine and am happy with it.Note,Make sure the type you get has aluminum core! Not steel.
nitro_rat thanked for this post
04-09-2017, 08:15 PM #45000 RPM
- Jul 2014
- Mississippi
- 196
- 18
What size did you use? So far I've ordered two different sizes , one said 4.5 mm and the other was 1/4" . The 1/4" one is too small in a few areas
04-09-2017, 08:44 PM #5
I'll look at the roll tomorrow.Seems like mine fits 5/16 through 3/8
04-09-2017, 08:55 PM #65000 RPM
- Jul 2014
- Mississippi
- 196
- 18
Where did you order it from? How did you secure it on the ends where it meets the transom?
04-09-2017, 09:04 PM #7
It came from an company that supplies RV builders.I used a small bead of 5200 just for insurance,one small trim screw each side at the transom(painted black you can't see it)
04-09-2017, 09:20 PM #8
Im going through this right now as well. Tried 1/4 and was too small. Next im trying 3/8
Modded Hydrostream Vking
Hydrostream Vking
Hydrostream Viper
Sold, Hydrostream Vector, Allison xb2002
04-09-2017, 09:20 PM #95000 RPM
- Jul 2014
- Mississippi
- 196
- 18
Do you have contact info for them so I can order some? I'm getting close to finishing up my Vector and the stuff I ordered won't work
07-05-2017, 07:55 PM #106000 RPM
- Aug 2015
- Southeast
- 1,068
- 134
- 79
- 48
- 614
I also need to get some. I found the Taco Universal Flex Trim but it's in 25 foot length so you can't do a boat with one piece. Any ideas where to get a longer piece? https://www.jamestowndistributors.co...sal+Flex+Trim#
07-05-2017, 10:18 PM #115000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I tried several different sizes and the 5/16" from McMaster Carr fit perfect. I put a bead of 3M 5200 adhesive on it to make sure it didn't get pulled off.
07-06-2017, 01:27 AM #12
Have you had a look at some of the new boats on the yards to see what they use ! they still have the same problems now that others had long time ago !!
Try also a company that manufactures and extrudes lengths of plastic mouldings and beadings !((yellow pages ) I found one such place a while back and they had just what I wanted in stock left over from another job !even the coloured infill in bright red just what I needed .Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
07-06-2017, 05:07 AM #13
W2F a V-King liked this post
07-06-2017, 06:54 AM #14Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
07-06-2017, 09:15 AM #15
Alright for a hydrostream with the stock aluminum rail. The 5/8th id from taco marine fits great. Without the rub rail m master carr sells a vinyl rubrail similar to the taco marine and its made for 1/4 to 1/2 and it fits about the best ive found. If you redo your deck and make it thicker it might not work and you might need bigger sizes. Hope this helps!
Hydrostream Vking
Hydrostream Viper
Hydrostream Vking Rub Rail Replacement
By mdhilto in forum Misc. Parts and AccessoriesReplies: 2Last Post: 03-16-2017, 12:22 PM -
Hydrostream Emblems & hydrostream bottom rail
By Dennyhydrostream in forum Parts WantedReplies: 0Last Post: 09-22-2015, 06:07 PM -
hydrostream vking
By Image 21 in forum Hulls WantedReplies: 1Last Post: 02-05-2014, 09:12 PM -
Hydrostream vking yt with 2.4 225
By dusty7075 in forum Props, Setup, and RiggingReplies: 7Last Post: 08-23-2013, 04:23 PM -
Hydrostream vking help
By gorillapowered in forum Fiberglass and Composites DiscussionReplies: 30Last Post: 02-16-2012, 05:42 PM
