Results 1 to 7 of 7
Thread: Allison trans queston
04-08-2017, 02:05 PM #1
My son recently bought an older Chevy p/u with the fuel efficient 8.1 and Allison trans. Has about 150k miles. He doesn't know the service history on the trans but wondered if it should be serviced. Our experience with conventional trans has been if it hasn't been serviced ever or in a long time and then do a fluid and filter change, it's a death sentence for the trans. Is the same true with the allisons? Should we service it? Or.... if it works- don't mess with it? Thanks
04-08-2017, 02:32 PM #2
i agree with the death sentence of new fluid in a varnished up trans. but disagree with your fuel efficient 8.1 statement.
04-08-2017, 06:14 PM #3
davemvegas liked this post
04-08-2017, 09:51 PM #4
Why is it a death sentence to put new fluid in an old trans.
Quartermaster
XB2002 W/S3000
04-08-2017, 09:57 PM #5
04-08-2017, 10:18 PM #6
That's correct, trans fluid has a lot of detergents that'll loosen up wear material that is in its happy place, and it'll get into the valve body and clutch pistons and cause them to stick and not move freely resulting in trans damage. Check condition of trans fluid, is it discolored or a darker color and how does it smell. If it's still reddish and doesn't have smell other than trans fluid you'll be ok to change. If it's discolored or has a smell don't mess with it.
sonicss33 liked this post
04-08-2017, 11:58 PM #76000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,237
- 55
- 300
- 2748
- 3876
Also you could just pull the external spin on filter and empty it to see what it looks like. Remember there are 2 filters on it. Internal and external.
Queston on lower's
By akuczera in forum Technical DiscussionReplies: 2Last Post: 08-26-2016, 08:15 AM -
Oil Queston?? Need Help!!
By Ktrain in forum Technical DiscussionReplies: 0Last Post: 07-12-2006, 09:51 PM -
Queston>>>>>>
By reefhead99 in forum The Scream And Fly LoungeReplies: 22Last Post: 09-23-2005, 01:33 PM -
Fuel rigging queston
By Techno in forum Technical DiscussionReplies: 10Last Post: 04-06-2003, 09:13 AM -
queston for racer
By speedracer in forum Technical DiscussionReplies: 1Last Post: 03-31-2002, 02:14 PM
