Results 1 to 3 of 3
    Sep 2015
    Twin Cities, Minnesota
    Adding an additional Tilt switch
    I have an extra mercury Tilt switch and I would love to mount it to the back of the boat because its a real bitch running back and forth trying to set the transom saver pole by yourself.
    So I have a Tilt/Trim switch up front. But in order to ad another one. How would I wire it as a secondary switch?
    Rhode Island
    @ your motor, just "T" into the tilt wires. Red, Green, and Blue? Or black.
    Mount it up under your cowl on the side the tilt arm is on. less wiring mess.
  1. Wring up a jack plate switch, use the trim/tilt switch?
    By leaky in forum Props, Setup, and Rigging
    Last Post: 03-27-2015, 07:02 PM
  2. Adding trim and tilt: '82 Merc 115?
    By gw204 in forum Technical Discussion
    Last Post: 02-17-2011, 07:48 AM
  3. Mercury Tech: Adding power trim and tilt?
    Last Post: 10-25-2010, 03:51 PM
  4. Question on Mercury Power tilt adding fluid
    By RChabit in forum Technical Discussion
    Last Post: 08-07-2008, 02:33 PM
  5. Adding trim/tilt & electric start to Mariner 40
    By riverrat321 in forum Technical Discussion
    Last Post: 08-22-2005, 08:39 AM
