Results 1 to 15 of 21
Thread: WTB a 14 x 24 Raker
04-04-2017, 07:20 PM #15000 RPM
- Nov 2005
- NE Alabama - Weiss Lake
- 702
- 7
WTB a 14 x 24 Raker
I am looking for a 13 7/8 or 14 x 24 Raker. I am not an Evinrude guy but now I have a 1996 70hp with a 20" shaft. I don't know how many splines I need but if you are an OMC guy you will know. Thanks
TJ309
Older 17 foot Laser / 2.5L Merc 245 Racer
1993 Speedster 13 / 2019 Merc 60 play boat
2020 Lowe 24' Pontoon boat / 250hp Merc. 51mph!
72 Hydrodyne bubbledeck undergoing keel up restoration
2 Jetski's
04-04-2017, 08:47 PM #2Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1269
- 368
13 splines
04-04-2017, 09:19 PM #35000 RPM
- Nov 2005
- 702
- 7
Thanks. That helps.
TJ309
2 Jetski's
04-05-2017, 07:43 PM #4Team Member
- Lake Coochiching, Ontario
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
I have one that I probably don't need. I used it occasionally on my old family boat. When do you need it? I would like to try mine on the new boat when the ice is gone. It will be a huge surprise if the new boat needs a 24" prop.
is your boat a small light V bottom? Maybe you should try a 23SRX.Last edited by David; 04-05-2017 at 07:46 PM.
04-05-2017, 07:49 PM #55000 RPM
- Nov 2005
- 702
- 7
I am not in a hurry. My boat is a small 13' light V bottom. Who makes the 23SRX?
TJ309
2 Jetski's
04-06-2017, 07:50 PM #6Team Member
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
OMC made the 23SRX and DAH was/is famous for tuning the SRX. They come up for sale from time to time. The 23SRX would be good for your boat. I had one on a similar boat (Voodoo with 70 Yamaha)
I will try my Raker once on the new boat when the ice melts in a month...
05-12-2017, 04:48 PM #75000 RPM
- Nov 2005
- 702
- 7
Still looking for a Raker or a 23SRX
TJ309
2 Jetski's
05-22-2017, 08:32 PM #8
the srx you refer too was called the silver streak by OMC.
it was originally made for the omc v4 motors back in the 1970's. Lots of the v4 140's ran the prop with some pretty good speeds.
like said above DAH are the experts to tune these props, might due to the owner of DAH being the guy who designed the prop.
But being 13 splines most people who have these use them on the johny/rude 60 and 70hp triples on light hulls.
the srx is the name of the latest versions of this made made inly in 15 spline for the larger engines, but the silver streak wasa metallic silver painted prop.
once the paint is off and the prop polished its an srx and pretty easy to tell what it is.
its also an over hub prop with a rubber hub .
the 13 spline prop came in just the one size....13 3/4 x 23 pitch 3 blade. its often called a semi cleaver.
hope that helps a bit.
06-24-2017, 10:30 AM #9
I have a 24' Raker for sale
True Viking
Scarab 34 SS with Triple OMC 4.0 V8's
06-24-2017, 03:10 PM #105000 RPM
- Nov 2005
- 702
- 7
What condition and how much? Will it fit my 70 Evinrude?
TJ309
2 Jetski's
06-24-2017, 03:36 PM #11
Look it up on eBay. I'm a little busy right now but plenty of pics on there.
True Viking
06-24-2017, 07:14 PM #125000 RPM
- Nov 2005
- 702
- 7
Which one is yours? Will a 14.5" fit my motor?
TJ309
2 Jetski's
06-24-2017, 07:49 PM #13
The pair, seller Flying Norseman
True Viking
06-24-2017, 08:40 PM #145000 RPM
- Nov 2005
- 702
- 7
Are you selling the pair on e-bay? I only need one. I couldn't find your listing. Also there are a lot of 14.5" listed - not sure if that will fit my motor.
TJ309
2 Jetski's
06-24-2017, 08:51 PM #15
I am not sure if it fits either. But the part number is 394754 so I guess one could look it up.
True Viking
Raker props -> Raker vs Raker II
By MarkOliver in forum Props, Setup, and RiggingReplies: 19Last Post: 09-02-2012, 09:12 PM -
raker vs. raker II
By nate. in forum General Boating DiscussionReplies: 4Last Post: 01-19-2012, 11:22 AM -
OMC Tech: What's the difference Raker & Raker II? Prop
By decoy033 in forum Technical DiscussionReplies: 3Last Post: 05-17-2010, 04:30 AM -
OMC Tech: Whats the difference between raker and raker II props
By antonietti in forum Technical DiscussionReplies: 1Last Post: 12-28-2008, 10:46 AM -
21p raker ok?
By jjy73 in forum Props, Setup, and RiggingReplies: 1Last Post: 07-02-2004, 06:17 AM
