Results 1 to 6 of 6
    Mar 2017
    Southern Indiana
    1974 to 1976 omc v4 crankcase or powerhead
    As the title says, I need a powerhead or bare crankcase with a 3.5" bore to fit a 1976 135 motor.
    Thanks.
    Aug 2009
    Florence SC
    I have a couple of them, already disassembled.
    Block- $ 100, naked, (have a few exhaust humps,( $ 50) but stuffers are Questionable)
    Crank- $ 50
    rods- $ 20 ea
    * note heads are NOT included in above. all are plus shipping.
    Located in Florence SC.
    will also barter /trade/ v4 looper parts.
    Jul 2012
    Lufkin, Texas
    A buddy of mine has an old 135 that's a runner. He might let it go, but I bet he would want to keep the heads! I think it's a '74. PM me if you want me to ask him about it.
    Josh Peterson
    Mar 2017
    Southern Indiana
    Thanks for the help. I may check with you abouut that. Excuse my ignorance, but what's so special about the heads?
    Jul 2012
    Lufkin, Texas
    They have a smaller combustion chamber for higher compression. Some race classes don't permit "modified" parts but will allow swapping "stock" parts that are interchangeable. So instead of cutting the heads on a 140, you find a set of early 135 heads to boost the compression and it's "legal."
    Those early 135's have 145-150 psi cranking compression if they're healthy. It's too much for today's pump gas. If you run a tank of 87-89 octane through one you'll burn it down. Best to use some later 140 heads anyway, or take some timing out for recreational use.
    Josh Peterson
    Mar 2017
    Southern Indiana
    I didn't know that. Thanks.
  1. Crankcase sealing
    By alinder225 in forum Technical Discussion
    Last Post: 03-30-2016, 10:37 PM
  2. 1973 and 1974 v4 115 / 1976-1977 v4 140
    By ShiftyOne in forum Technical Discussion
    Last Post: 10-10-2004, 10:10 AM
  3. 1974 9.9 omc
    By ChampMan in forum Technical Discussion
    Last Post: 06-10-2004, 11:41 PM
