Results 31 to 45 of 53
  1. #31
    That is a well built boat. It will not fall apart ever. I love seeing boats built for the long run and able to have any power on it you choose. Very, very cool boat.....Excellent job with it. Can't wait to see a running vid and performance specs....
    Aug 2004
    Venice, Florida
    Has a very Speed Racer Mach 5 look to it.
    21' Paramount
    Mercury 300 Promax
  3. #33
    Shreveport, La.
    Different for sure and I like it. As has been said I can`t wait to see some performance numbers. I know like all new design`s there will be some "tweeking" so I will be patient.
    DB
  4. #34
    Feb 2017
    Wixom lake michigan
    Really, really nice! Looks like it would take a beating and ask for more!
  5. #35
    Mar 2015
    bunnell FL/old town FL
    Subscribed very cool
    2003 mirage ski racer with e-tec power
  6. #36
    Jun 2002
    Winter Haven Fl.
    Do the outside sponsons have any dihedral? They look very flat and has this hull ever been tested or will you be the first? Boat looks great can't wait to see the finished product.
  7. #37
    #2 iron from the Mayo clinic, Fla. / Blue Ridge, VA.
    I cannot tell you how impressed I am of your work! your facility looks to be about 10k sq ft? what did you do before purchasing the Talon molds? obviously you are not a newcomer to boat building. you are inspiring me to get my ass in gear. why do you let all that hair to stay on the piece after cured? at sea ray we always took a razor knife and trimmed that off just as it was kicking. fun out
    most overnite successes usually take at least 10 years
    Certified turd polisher,
  8. #38
    Ohio
    Quote Originally Posted by mr fun View Post
    Thank you for the compliment. The main building there is 18,000 SF. I also use another building that belongs to my dad that is about 8000 SF. We use that building for storage mostly. If we hand layup, I like to leave extra glass over the sides for a few reasons. Instead of driving a wedge inside the mold, we bend the glass over, 90 degrees, wet it, let it dry and use it as leverage for applying pressure on the part to make it come out of the mold easier with wedges. I also, like leaving extra glass over and wetting it out, so the tops of the part will not be dry. Just a bunch of little reasons like that. I try to keep anything away from the molds that will damage them. My guys are good and cautious, but getting things like razor blades close to them will sometime resort in damage to the top of the molds, because accidents happen. When we vacuum bag or infuse, there is nothing above the top of the molds. Thanks, Todd
  9. Likes Frank Molé, AZMIDLYF, JasonRS liked this post
  10. #39
    Ohio
    I forgot to answer one of your questions. This is probably the best explanation to that question http://www.screamingeagleboats.com/about.html
  11. #40
    Quote Originally Posted by Screaming Eagle Boats View Post
    WOW, quite humbling. hope to meet you somewhere down the road. are you related to a yacht broker in Jax Fla by the name of Lamb?
    https://www.lambsyachtcenter.com/
  12. #41
    Ohio
    No, not related or at least not a close relation to that Lamb. I am related to most of the Lamb's in car, drag and boat racing.
  13. Likes Frank Molé liked this post
  14. #42
    Minnesota (play) / Michigan (work)
    Quote Originally Posted by oldschoolltv View Post
    It has been tested with both outboard and Jet at one time, I came across the outboard version after we started the build. It has very little deadrise if any, center pod is below the sponsons. There are a few things we could do to make it faster but want to test it myself and see what it needs.
    Not fast enough
  15. #43
    Do the outside sponsons have any dihedral?.
    have any what ??? splain please
  16. #44
    SE MN
    Deadrise
    Jun 2002
    Winter Haven Fl.
    The angle on the sponsons, flatter is faster but you can get a porpoise if too flat, at least this was how it is on a true tunnel.
  1. Screaming Eagle Boats New Edge 22 Cat
    By Spectre Powerboats in forum General Boating Discussion
    Last Post: 05-19-2020, 11:27 AM
  2. Screaming Eagle Boats Mark's Talon 22 SS
    Last Post: 06-18-2017, 10:10 PM
  3. Screaming Eagle Boats
    Last Post: 03-23-2017, 07:03 AM
  4. Screaming Eagle Boats Kim's Talon 22 SS
    Last Post: 03-19-2017, 03:48 PM
  5. Screaming Eagle Boats & Todd Lamb
    By aggiestckl in forum General Boating Discussion
    Last Post: 11-09-2016, 10:31 PM
