Results 61 to 68 of 68
Thread: Floor question
09-12-2017, 09:19 PM #615000 RPM
- Mar 2015
- DFW
- 665
- 16
- 42
- 366
- 232
ole tunnels types a lot but he sure doesn't say anything... let it go dude...
09-13-2017, 04:52 AM #62Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
10-02-2017, 06:52 PM #63Member
- Jul 2016
- Winchester ky
- 68
- 20
Sorry this picture is probably going to be upside down. This is the project that started all this. The floor is in, the seat base is in and I am working on a semi permantly mounted 12 gallon tank along with the battery in the very back. No longer will the tank be under the bow.
This has taught me a lot about epoxy-glass and I am impressed how much stronger the hull is. Thanks for all your help and can't wait to get back at it! Don't go anywhere, I got more questions!
Jerry
olboatman liked this post
10-06-2017, 08:02 AM #64Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Very clean glassing.
10-06-2017, 03:58 PM #65"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
10-07-2017, 08:38 AM #66Member
- Jul 2016
- Winchester ky
- 68
- 20
The front wall of the seat base has a two inch wide gap for ventilation and water to pass thru. I have to make the drain in the back wall and seal it. The previous owner put a wood floor in and used some sort of white sealer or paint. It was molded and soft and my understanding is it was less than a year old. Therefore I have been overly cautious on the sealing. I am using epoxy and biaxial cloth. The inside of the seat base is completely sealed with epoxy.
Does your boat have core construction?
10-07-2017, 08:53 AM #67Member
- Jul 2016
- Winchester ky
- 68
- 20
XSTREAMVKING
THANKS!
This is the way I interpreted your instructions. Worked great imo. I was intending on 3/4 wood, but after seeing the results, 3/4 wood have been overkill dramatically, and way to heavy. Thanks again for your knowledge, you have also set the formula for the rest of the build.
Jerry
10-07-2017, 09:51 AM #68
Redoing floor/ drop floor
By gmjim in forum Fiberglass and Composites DiscussionReplies: 1Last Post: 08-09-2013, 07:58 AM -
In floor heat and a in floor fish tank.
By JrCRXHF in forum The Scream And Fly LoungeReplies: 9Last Post: 01-08-2010, 01:33 PM -
Floor question
By northeastcat in forum Fiberglass and Composites DiscussionReplies: 20Last Post: 06-16-2009, 02:18 AM -
Floor Replacement Question --- HELP !
By RB in NM in forum Fiberglass and Composites DiscussionReplies: 6Last Post: 01-13-2008, 10:08 PM -
Floor/hull strength question
By fkeys in forum Jet Boats, V-Drives and Stern DrivesReplies: 3Last Post: 04-04-2004, 11:40 AM
