Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 68 of 68
Thread: Floor question
  1. #61
    Mar 2015
    DFW
    ole tunnels types a lot but he sure doesn't say anything... let it go dude...
  2. #62
    Jul 2007
    Have lived and worked in New Zealand ,Tahiti,Australia,Japan , south Korea, And now Suzhou in China
    Wow now whos the keyboard tough guy???? Or did you mean you were just gonna produce your scrap book?
    with all the crap weather you guys been having im glad to be 10,000 ks away !Tunnel boats =http://www.screamandfly.com/showthread.php?329705-STRAKES-what-are-the-there-for-and-what-do-they-do-and-can-they-do-anything-for-you
  3. #63
    Jul 2016
    Winchester ky
    Sorry this picture is probably going to be upside down. This is the project that started all this. The floor is in, the seat base is in and I am working on a semi permantly mounted 12 gallon tank along with the battery in the very back. No longer will the tank be under the bow.
    This has taught me a lot about epoxy-glass and I am impressed how much stronger the hull is. Thanks for all your help and can't wait to get back at it! Don't go anywhere, I got more questions!
    Jerry
  4. Likes olboatman liked this post
  5. #64
    Very clean glassing.
    Ft. Lauderdale, Fl
    Looks good. What are you going to do for a drain for the front section? remember to seal the inside of whatever drain hole you make. Is the inside of the seat base sealed or glassed? Did mine separate so I didn't need a drain in the floor....
  7. #66
    Jul 2016
    Winchester ky
    The front wall of the seat base has a two inch wide gap for ventilation and water to pass thru. I have to make the drain in the back wall and seal it. The previous owner put a wood floor in and used some sort of white sealer or paint. It was molded and soft and my understanding is it was less than a year old. Therefore I have been overly cautious on the sealing. I am using epoxy and biaxial cloth. The inside of the seat base is completely sealed with epoxy.
    Does your boat have core construction?
  8. #67
    Jul 2016
    Winchester ky
    XSTREAMVKING
    THANKS!
    This is the way I interpreted your instructions. Worked great imo. I was intending on 3/4 wood, but after seeing the results, 3/4 wood have been overkill dramatically, and way to heavy. Thanks again for your knowledge, you have also set the formula for the rest of the build.
    Jerry
  9. #68
    Ft. Lauderdale, Fl
    Quote Originally Posted by Ramonepb View Post
    Mine was an '84 Baja, not sure if it had a core since the hull was solid except for the dash, a section of the floor and the transom.
  1. Redoing floor/ drop floor
    By gmjim in forum Fiberglass and Composites Discussion
    Last Post: 08-09-2013, 07:58 AM
  2. In floor heat and a in floor fish tank.
    By JrCRXHF in forum The Scream And Fly Lounge
    Last Post: 01-08-2010, 01:33 PM
  3. Floor question
    By northeastcat in forum Fiberglass and Composites Discussion
    Last Post: 06-16-2009, 02:18 AM
  4. Floor Replacement Question --- HELP !
    By RB in NM in forum Fiberglass and Composites Discussion
    Last Post: 01-13-2008, 10:08 PM
  5. Floor/hull strength question
    By fkeys in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 04-04-2004, 11:40 AM
