Results 1 to 15 of 17
03-26-2017, 01:02 PM #15000 RPM
- Dec 2015
- Sarasota FL.
- 116
- 47
- 31
- 30
What is the best filler for blending in a nose cone
Seems like the Bondo with the fibers in it is still coming off too easily...is there anything better?
Thanks
03-26-2017, 03:08 PM #25000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
I've repaired chips and the like with JB Weld and it has held up.
Ventura Boy thanked for this post
03-26-2017, 03:37 PM #3
Splash zone epoxy works great due to its ease to shape and fill. But kinda pricey for just one job. Gotta make sure to rough metal and rub in until has good adhesion to metal before start building up.
03-26-2017, 03:46 PM #4
PC 7 has worked well for me. PC 11 is the marine version which I don't think is necessary. Both available at Ace hardware or Home Depot
03-26-2017, 03:52 PM #5
what size or thickness is the ridge between cone and case ?
03-26-2017, 07:00 PM #65000 RPM
- May 2004
- Eastern PA
- 592
- 29
- 53
I've used Marine Tex with great success on lowers and every place else for that matter.
03-26-2017, 11:09 PM #7
03-26-2017, 11:18 PM #8
In my last photo, which is an Evinrude XP200 with a Land and Sea cone. The nosecone is about 1/8" thick where it buts into the edge of the original lower unit. If you note there is about a 1 1/2" bridge between the raw aluminum and nose cone which makes a very smooth transition. so the filler material goes from nothing to only 1/8" thick which is the white stuff which is marine tex.
03-27-2017, 03:29 AM #9
why not make your own filler with epoxy resin and aluminum powder?
https://www.amazon.com/Pounds-Alumin.../dp/B00KF598X0
powerabout liked this post
03-27-2017, 09:35 AM #10"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
03-27-2017, 09:40 AM #11
if your going to sand aluminium then put a bit of wax on the paper, it helps keep it clean, same with grinding wheels !!! it actually works.
olboatman thanked for this post
03-27-2017, 10:24 AM #12
That's the good thing about the splash zone, you wet your hands and can get it shaped so that there is very little sanding. I made my torque tan with it and shaped it like I wanted it with little dress up. That stuff works like pottery lol. It's what I also do the stuffing and filling in blocks with. So use plenty of it. Sucks to buy it for just one job though. It takes some getting used to, but once you get it figured out how to work the stuff it's great!
03-27-2017, 10:25 AM #135000 RPM
- Dec 2015
- Sarasota FL.
- 116
- 47
- 31
- 30
Where do I buy the splash zone ?
03-27-2017, 10:31 AM #14
I got mine from divers supply in harahan La.
03-27-2017, 10:38 AM #15
I think Jamestown distributors has in 1 qt size. Found works better to mix as dry you can with least amount water. Rub into metal until it is stuck then build up. Wet your hands and begin to work and smooth it out until it's like you want it. Here's an oil pump void I filled with it, takes very little work afterwards to dress it up
Krazymaan liked this post
Nose cone on
By vnemous in forum General Boating DiscussionReplies: 34Last Post: 02-03-2013, 11:12 PM -
nose cone filler???
By R.I.P. in forum Technical DiscussionReplies: 31Last Post: 12-14-2012, 10:50 PM -
cavitation burns on nose cone filler.
By WATERWINGS in forum Technical DiscussionReplies: 9Last Post: 01-18-2009, 09:04 PM -
How does your Bob's nose cone kit fit???
By Hottrucks in forum Technical DiscussionReplies: 5Last Post: 05-22-2004, 02:43 PM -
Nose cone?
By Burke Kilgour in forum General Boating DiscussionReplies: 17Last Post: 07-15-2003, 04:48 PM
