Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
    Quote Originally Posted by stoker2001 View Post
    what is up with that oval window and never seen one so wide directly above wrist pin!!
    It's just another way to lighten the piston . Four stroke's you don't want to make any oil traps , so you mill the beam on the inside . Two strokes you don't want to add to the crankcase volume , so you mill a slot on the outside .
    And yes , to weight match a set of rods , you weigh the big and little ends as well as shoot for an overall that match's your lightest rod .
    The cutters are not cheap , but you can taper bore 20 gram's out of the pin's without losing it's integrity ...
  2. Likes FORBESAUTO liked this post
  3. #17
    Sep 2015
    Twin Cities, Minnesota
    Quote Originally Posted by HStream1 View Post
    I dont think they are oval. its just the angle of the picture creating that Illusion.
    Nope, Its oval.
  4. #18
    Sep 2015
    Just looked at mine and they are tapered as you mentioned. Not sure if I would have ever noticed that.
  5. #19
    Folsom, Cal
    Dewitt DeWeese (boatworks) taper bored me a set decades ago (78G).still run them to this day in drag 2.5
    "Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
    2007 Sportsmen Driver of the Year
  6. #20
    Sep 2015
    MIne are at 81 grams.
  7. #21
    May 2002
    Lake Havasu City AZ
    Drilled rods! Awesome. I always wanted to do that but was afraid of making a 5 cylinder powered fly cutter! When you drilled the holes did you use a flapper wheel or swizzle stick to polish and radius the holes to remove the stress risers? They look great by the way.
  8. #22
    Sep 2015
    Quote Originally Posted by rude tim View Post
    If your talking to me, I don't know what was used, they came that way. Those were jon wright's from a 2.5 drag engine, which I have on another post with photos.
  9. #23
    Actually they are not Drilled. But Milled in a Jig on a milling machine so all the holes are equally spaced and all rods exactly the same. And YES!!! The holes are smoothed and rounded on all the edges.
  1. Connecting Rod Weight
    By seansbaja1982 in forum Technical Discussion
    Last Post: 07-04-2012, 08:51 PM
  2. Balancing rods..factory has 30 grams difference
    By boilerdawg in forum Technical Discussion
    Last Post: 09-04-2006, 09:36 AM
  3. when balancing rods and pistons
    Last Post: 08-07-2006, 03:45 PM
  4. balancing connecting rods
    By Riverratt in forum Technical Discussion
    Last Post: 01-02-2004, 02:23 PM
  5. connecting rods
    By Skittles in forum General Boating Discussion
    Last Post: 09-06-2002, 08:09 PM
