Results 16 to 23 of 23
Thread: weight balancing connecting rods
03-27-2017, 07:37 AM #16
It's just another way to lighten the piston . Four stroke's you don't want to make any oil traps , so you mill the beam on the inside . Two strokes you don't want to add to the crankcase volume , so you mill a slot on the outside .
And yes , to weight match a set of rods , you weigh the big and little ends as well as shoot for an overall that match's your lightest rod .
The cutters are not cheap , but you can taper bore 20 gram's out of the pin's without losing it's integrity ...
FORBESAUTO liked this post
03-27-2017, 07:45 AM #17
03-27-2017, 07:48 AM #18
03-27-2017, 06:13 PM #19
Dewitt DeWeese (boatworks) taper bored me a set decades ago (78G).still run them to this day in drag 2.5
"Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
2007 Sportsmen Driver of the Year
03-27-2017, 09:56 PM #20
MIne are at 81 grams.
03-28-2017, 02:10 AM #21
Drilled rods! Awesome. I always wanted to do that but was afraid of making a 5 cylinder powered fly cutter! When you drilled the holes did you use a flapper wheel or swizzle stick to polish and radius the holes to remove the stress risers? They look great by the way.
03-28-2017, 07:47 AM #22
03-28-2017, 07:53 AM #23Bud Conner "Heathen" "Defending Our Constitution"
Connecting Rod Weight
By seansbaja1982 in forum Technical DiscussionReplies: 2Last Post: 07-04-2012, 08:51 PM -
Balancing rods..factory has 30 grams difference
By boilerdawg in forum Technical DiscussionReplies: 9Last Post: 09-04-2006, 09:36 AM -
when balancing rods and pistons
By boilerdawg in forum Technical DiscussionReplies: 2Last Post: 08-07-2006, 03:45 PM -
By Riverratt in forum Technical DiscussionReplies: 15Last Post: 01-02-2004, 02:23 PM -
connecting rods
By Skittles in forum General Boating DiscussionReplies: 1Last Post: 09-06-2002, 08:09 PM
